what have you done with stock FI and performance mods?, quest for a killer D-jet 2056cc motor |
realred914 |
Nov 13 2010, 08:08 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc.... will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat. what can be done during rebuild to beef up the power???? |
TargaToy |
Nov 15 2010, 09:23 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
For you guys with experience, what kind of power could one hope to achieve with a fuel injected 2056 (D-Jet OR L-Jet) assuming the entire system was optimized as per Jake's recommendations? I've been following almost every string on the subject and it often seems the big hp numbers and drivability claims are from owners of carbed cars. Is there no hope to make 120-130 hp with a tuned EFI TIV? Is it the intake runners or the cams or what that are the major hurdle?
roadster fan |
Nov 22 2010, 03:08 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Is there no hope to make 120-130 hp with a tuned EFI TIV? Is it the intake runners or the cams or what that are the major hurdle? The MPS. The issue is with the Djet or Ljet as it is not easily modified/tuned for performance gains. It is an old system that works great in a stock configuration but you are limited to tweaking the MPS. If you went aftermarket EFI the limit is your checkbook and tuning expertise with the type4. Many have used Megasquirt, SDS, and other aftermarket EFI systems with good success. How ambitious are you? I think post #41 says all you need to know about the combo to use with D-jet. Jim |
Bleyseng |
Nov 23 2010, 10:14 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Is there no hope to make 120-130 hp with a tuned EFI TIV? Is it the intake runners or the cams or what that are the major hurdle? The MPS. The issue is with the Djet or Ljet as it is not easily modified/tuned for performance gains. It is an old system that works great in a stock configuration but you are limited to tweaking the MPS. If you went aftermarket EFI the limit is your checkbook and tuning expertise with the type4. Many have used Megasquirt, SDS, and other aftermarket EFI systems with good success. How ambitious are you? I think post #41 says all you need to know about the combo to use with D-jet. Jim They are both a challenge to adjust to "tune" but it can be done. In a way since they are the only way to set the AFR easier then a Modern EFI with nearly infinite options. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:51 AM |
