CHT removal |
CHT removal |
Ray Warren |
Apr 22 2004, 06:52 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
Do I have to remove the intake runner to get my
cylinder temp sender out? And what size socket is it? Engine is a 1.7. |
TheCabinetmaker |
Apr 22 2004, 07:08 PM
No, on the intake runners. I "think" a 13/16 spark plug socket will work. Grind one corner from a short socket extension so the wire will pass thru the top of the socket, or cut a slot in the side of the socket.
Mark Henry |
Apr 22 2004, 07:32 PM
It's 13mm, there is a special socket for it or do the above. Soak it in P-oil for a couple of days and make an offering to the Porsche gods. (IMG:style_emoticons/default/pray.gif)
If you are replacing it anyways just snip the wire off. |
DNHunt |
Apr 22 2004, 07:35 PM
Amen to that. Very easy to remove aluminum threads from the head with the CHT.
Dave |
nebreitling |
Apr 22 2004, 07:42 PM
what a PITA job... make sure you need to do it. i made a special socket driver out of wood with a slot for the wire to pass through it. then, just used a deep 13mm socket. the manual calls for a "socket wrench" that i've never seen.
good luck, nathan |
SLITS |
Apr 22 2004, 10:59 PM
Geeeeez - buy a 13 mm deep socket and using a dremel tool cut a slot in the side for the wire to pass thru.
If you don't have a dremel tool, use a hacksaw. Or cram the wire up inside the deep socket - |
Lo-Fi Version | Time is now: 17th May 2024 - 05:18 PM |
