Official Sasquatch build thread Part 1, Cosmo Rotary Turbo... Then boom... |
Mike Bellis |
Nov 20 2010, 02:20 PM
Many of you know my car. It was Steve Malmz's car he found in a yard as a roller. It was a former SCCA club racer. Malmz named the car Sasquach. Malmz put a V8 in it and drove it until his priorities changed. It was sold to a guy in Kentucky (unknown name), he regeared the transaxle and drove it little. He sold it to a PCA member in Irvine, CA. That guy used it as a DE car until I purchased it. I installed an EFI system and drove the crap out of it. Recently my clutch went out and I decided it was time for a change. The V8 is going to another member. My engine choice is
The car has 930 suspension and brakes. 930 steel flairs grafted on, a total of 8 flairs were used. Two per corner to make up the radius. There is a roll cage with removable door bars. The cage is tied to the rear suspension but not the front. The bodywork ant paint are 10+ years old and the car is several shades of white. The chassis is super solid. Only minor surface rust has been found. The Original owner/racer installer a stiffening kit and various braces. The suspension console is unusual. Steel plats replace the inboard pivots. 1/8" & 1/4" plate steel reenforcement plates are surrounding the console. A 1" bar ties in the console to the firewall. Here are the first pics of me stripping paint from the engine bay and the unusual consoles. |
strawman |
Nov 20 2010, 05:42 PM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Subscribed! Good luck Mike; let me know if you need any help. Maybe we could do a build/bbq party.
BTW, what's the story with the holes in the trailing arms? Are they rosette holes that were not welded in? Geoff |
Mike Bellis |
Nov 20 2010, 05:52 PM
Subscribed! Good luck Mike; let me know if you need any help. Maybe we could do a build/bbq party. BTW, what's the story with the holes in the trailing arms? Are they rosette holes that were not welded in? Geoff Exactly. Not shure why the PO or PPO or PPPO did not weld them all in when they added the stiffening plates. The console has me puzzeled too. I think I will end up adding material above the engine shelf to tie it in better. Not shown in pics is the back side under the console. The entire system is seam welded under there. I looks plenty strong. |
Lo-Fi Version | Time is now: 3rd May 2024 - 02:46 AM |
