Official Sasquatch build thread Part 1, Cosmo Rotary Turbo... Then boom... |
Mike Bellis |
Nov 20 2010, 02:20 PM
Many of you know my car. It was Steve Malmz's car he found in a yard as a roller. It was a former SCCA club racer. Malmz named the car Sasquach. Malmz put a V8 in it and drove it until his priorities changed. It was sold to a guy in Kentucky (unknown name), he regeared the transaxle and drove it little. He sold it to a PCA member in Irvine, CA. That guy used it as a DE car until I purchased it. I installed an EFI system and drove the crap out of it. Recently my clutch went out and I decided it was time for a change. The V8 is going to another member. My engine choice is
The car has 930 suspension and brakes. 930 steel flairs grafted on, a total of 8 flairs were used. Two per corner to make up the radius. There is a roll cage with removable door bars. The cage is tied to the rear suspension but not the front. The bodywork ant paint are 10+ years old and the car is several shades of white. The chassis is super solid. Only minor surface rust has been found. The Original owner/racer installer a stiffening kit and various braces. The suspension console is unusual. Steel plats replace the inboard pivots. 1/8" & 1/4" plate steel reenforcement plates are surrounding the console. A 1" bar ties in the console to the firewall. Here are the first pics of me stripping paint from the engine bay and the unusual consoles. |
Mike Bellis |
Dec 11 2010, 06:40 PM
Not much to update. I've been collecting parts. Here's a pic of the cleaned and painted engine. I put my Iphone in the pic to give an idea of just how small these engines are. Picture a type 4 without heads and cylinders. This little turbo engine will make 350hp at 15 psi with 250 ft lbs @ 4k
GT35R Ball bearing Turbo- oil and water cooled HKS cast iron exhaust manifold Haltech ECU HKS Blow off Valve HKS wastgate HKS Boost controller 2000cc injectors (x4) Areomotive fuel regulator Custom Rails 4" exhaust Aero Turbine Muffler Frozen Boost air to water intercooler Damn this conversion is getting expensive! |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:56 PM |
