Official Sasquatch build thread Part 1, Cosmo Rotary Turbo... Then boom... |
Mike Bellis |
Nov 20 2010, 02:20 PM
Many of you know my car. It was Steve Malmz's car he found in a yard as a roller. It was a former SCCA club racer. Malmz named the car Sasquach. Malmz put a V8 in it and drove it until his priorities changed. It was sold to a guy in Kentucky (unknown name), he regeared the transaxle and drove it little. He sold it to a PCA member in Irvine, CA. That guy used it as a DE car until I purchased it. I installed an EFI system and drove the crap out of it. Recently my clutch went out and I decided it was time for a change. The V8 is going to another member. My engine choice is
The car has 930 suspension and brakes. 930 steel flairs grafted on, a total of 8 flairs were used. Two per corner to make up the radius. There is a roll cage with removable door bars. The cage is tied to the rear suspension but not the front. The bodywork ant paint are 10+ years old and the car is several shades of white. The chassis is super solid. Only minor surface rust has been found. The Original owner/racer installer a stiffening kit and various braces. The suspension console is unusual. Steel plats replace the inboard pivots. 1/8" & 1/4" plate steel reenforcement plates are surrounding the console. A 1" bar ties in the console to the firewall. Here are the first pics of me stripping paint from the engine bay and the unusual consoles. |
RJMII |
Dec 11 2010, 10:20 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
QUOTE GT35R Ball bearing Turbo- oil and water cooled HKS cast iron exhaust manifold Haltech ECU HKS Blow off Valve HKS wastgate HKS Boost controller 2000cc injectors (x4) Areomotive fuel regulator Custom Rails 4" exhaust Aero Turbine Muffler Frozen Boost air to water intercooler So are you switching to single turbo with the ball bearing unit? |
Mike Bellis |
Dec 11 2010, 11:08 PM
So are you switching to single turbo with the ball bearing unit? Yes, Single. with new manifold. The stock twin turbos are nice in stock configuration but the single is far less complicated and will yeild more power. The turbo I'm using can get me up to 450-500hp @ 25+psi but I want the engine to remain reliable hence the 17psi max plan. It will look similar to this one... |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:27 AM |
