Official Sasquatch build thread Part 1, Cosmo Rotary Turbo... Then boom... |
Mike Bellis |
Nov 20 2010, 02:20 PM
Many of you know my car. It was Steve Malmz's car he found in a yard as a roller. It was a former SCCA club racer. Malmz named the car Sasquach. Malmz put a V8 in it and drove it until his priorities changed. It was sold to a guy in Kentucky (unknown name), he regeared the transaxle and drove it little. He sold it to a PCA member in Irvine, CA. That guy used it as a DE car until I purchased it. I installed an EFI system and drove the crap out of it. Recently my clutch went out and I decided it was time for a change. The V8 is going to another member. My engine choice is
The car has 930 suspension and brakes. 930 steel flairs grafted on, a total of 8 flairs were used. Two per corner to make up the radius. There is a roll cage with removable door bars. The cage is tied to the rear suspension but not the front. The bodywork ant paint are 10+ years old and the car is several shades of white. The chassis is super solid. Only minor surface rust has been found. The Original owner/racer installer a stiffening kit and various braces. The suspension console is unusual. Steel plats replace the inboard pivots. 1/8" & 1/4" plate steel reenforcement plates are surrounding the console. A 1" bar ties in the console to the firewall. Here are the first pics of me stripping paint from the engine bay and the unusual consoles. |
Andyrew |
Dec 11 2010, 11:12 PM
I still think your going to be pushing way more HP than that on a GT35R.... I guess at 15psi maybe... but that turbo is made to be pushed to like 35psi...
Mike Bellis |
Dec 11 2010, 11:23 PM
I still think your going to be pushing way more HP than that on a GT35R.... I guess at 15psi maybe... but that turbo is made to be pushed to like 35psi... My boost controller allows a scramble mode and a dual boost setting. I may push it a little. The 2000cc injectors are big enough to support over 700hp. They were recommended by Turblown. The ball bearing should help it spool and the water cooling will help keep it from burnig up. It will definitely be capable of higher hp numbers than I plan to run normally. |
Lo-Fi Version | Time is now: 3rd May 2024 - 12:18 AM |
