Timing and tuning help needed |
jdogg |
Apr 23 2004, 05:22 AM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Help! I set the timing on the car last night, but something doesn't seem right. When I set it to 27 btdc, the idle screams up to 3200 rpm. I had found both of the timing marks, so I verified my settings by dialing the timing light to 0 and then to 27, and hit both the marks on the money. Motor was warm, vacuum lines unplugged, and timing set at 3500 rpm.
Here are the specs on the motor: fairly recently rebuilt 2.0, D jet, (appears to be a '73 throttle body as it has a vacuum line to the backside of the vacuum advance on the dizzy) and it supposedly has a dizzy in it out of a 1.7, evidently the curve is different... So my questions are WTF do I do? Should the timing be set differently with this distibutor? Is there another way to dial the idle on down? Am I totally out to lunch? I do have a proper 2.0 dizzy, maybe do I need to just pop that in and try it? I tried turning the ECU knob, made no difference...the air bleed screw is cranked all the way in....the aar and cold start valve are plugged, decel valve is gone, no vacuum leaks that I can detect. What am I missing? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:24 PM |
