> carb popping 6 this time, everybody loves carb threads
dem
post Nov 26 2010, 10:59 AM
Rusty Member
Drove the 914 to turkey time yesterday, about 50 miles of backroads. Seemed to be runnin' about normal with the usual symphony of only-occasional random backfires and pops. It was, of course, ridiculously fun.
Car sat til I left around 10 PM, and by then it was around 40 degrees outside. Lots of popping and stuttering at part throttle. Full throttle and it was the usual fun excitement.
The ride home on the freeway was unpleasant because the 2.7L doesn't need much throttle to keep my little car moving. Could this just be temperature related? Idle jets sized for Los Angeles (where I bought it.)?
Otherwise I assume I'm looking at checking for gunk in the idle jets, I assume.
This is my first carbed porsche, so I guess it is time to really "grok" them. Is there an obvious "start here carb newbie" direction? Book and/or web site? Googling turns up tons and tons of random stuff.
Thanks.
dem   carb popping 6 this time   Nov 26 2010, 10:59 AM
sean_v8_914   pretend you have an early 911 and search web acord...   Nov 26 2010, 11:36 AM
J P Stein   Years back... early one morning in the spring I wa...   Nov 26 2010, 12:02 PM
Cap'n Krusty   I could be wrong, but I don't think being 300 ...   Nov 26 2010, 12:25 PM
Cupomeat   I could be wrong, but I don't think being 300...   Dec 12 2010, 07:02 PM
dem   Cleaned the idle jets with compressed air and carb...   Nov 26 2010, 04:13 PM
J P Stein   Your first post told me it wasn't running righ...   Nov 27 2010, 12:23 PM
dem   I've spent the last 24 hours reading tons of t...   Nov 27 2010, 12:53 PM
J P Stein   Get the float setting tool while you're at it....   Nov 27 2010, 01:22 PM
dem   Pulled and clean the idle jets.. no change. Pull...   Dec 1 2010, 08:20 PM
dem   Ok, I bought 5 books and googled a lot.. bought t...   Dec 11 2010, 02:47 PM
SirAndy   Two of the idle mixture screws (#5 and #6) did not...   Dec 11 2010, 04:51 PM
Mark Henry   I am, of course, terrified of running lean. A...   Dec 12 2010, 12:09 AM
john rogers   You seem to be getting on the right track. Several...   Dec 11 2010, 03:41 PM
dem   I try to drive it to full operating temperature at...   Dec 11 2010, 05:28 PM
9146986   Do you mean 5.5 half turns out or 5.5 full turns? ...   Dec 11 2010, 06:44 PM
dem   Do you mean 5.5 half turns out or 5.5 full turns?...   Dec 11 2010, 06:48 PM
sww914   The inside of the engine doesn't care how many...   Dec 11 2010, 07:51 PM
jt914-6   Here's a site I ran across that may help you.....   Dec 12 2010, 07:01 AM
dem   Thanks everyone for the tips - I took the car out ...   Dec 12 2010, 01:25 PM
J P Stein   Side to side balance is adjusted with the down lin...   Dec 12 2010, 04:57 PM
Rusty   Dem, I'm a little late here. I struggled with...   Dec 14 2010, 12:02 AM
Justinp71   One thing I learned about keeping the carbs clean ...   Dec 16 2010, 10:04 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 01:08 PM
