New GT Half Cage, limited availability, build to order |
McMark |
Nov 28 2010, 12:20 PM
I'm got a tubing bender to make a replica GT half cage for a customer car. This is the style of bolt in cage used on some of the GT cars pictured on Armando's AWESOME GT site, as well as the style used in the PMB GT.
Material is mandrel bent 1.75" DOM 0.95", notched and will be completely welded. Plates are laser cut steel, ensuring they look great and fit perfectly. You will be required to weld the provided receiver plates onto your longs. These cages will keep the seats from moving all the way back because of the center brace bars. I have some ideas that will adapt the cage to work better with stock seats. PM me for details. Also, these cages will obviously not work with a stock backpad, nor the door handle/pocket. Each cage will be $xxx in bare steel, with powdercoating available. Shipping is possible, we're probably looking at crate and freight shipping, which should be around $175 (give or take $25). Cages are built to order. --Optional Item 1-- Leave off the two bars going to the center hump. This would let you keep the backpad and knock $xxx off the price. --Optional Item 2-- Leave off the forward/door bars. These add a lot of rigidity, but make getting in and out of the car harder. Leave these off and knock $xx off the price. Custom alterations are also available at full shop rate of $125/hr for actual time spent beyond the building of the standard cage. These cages are now special order. Contact me for details. Installation Info: 1. Use a jack on both sides of the car, in the middle of car (between the wheels) with slight pressure simply to counteract the weight of the car. If you think about the way the weight is distributed, it's split between four wheels roughly equally. You're using the jack to try and distribute the weight six ways evenly. If you lift too much in the middle, you're changing the bias. This is not an exact science or setting. You just have to use your best judgement. 2. Test and measure the door gaps and opening closing effort before and during the welding process. Also measure between the targa bar and the windshield hoop, using the attached picture. Anything within 2-3mm is considered correct. But keep checking that measurement as you weld to make sure things aren't moving. 3. Do not run a bead longer than 1" ever on any joint. Long continuous welds are how cars get warped. 4. If you're using the bolt-in setup, weld the base plates in while they are bolted to the cage. Welding the base plates with the cage fully assembled ensures that everything lines up. 5. Get the cage to sit correctly, fully assembled, before fully welding a single piece. You cannot adjust things as you go. Get them all lined up, sitting flat, etc before you start permanently attaching things. 6. Tack weld the forward bars to the main hoop first, but fully weld the rear bottom plates first. Then weld the forward bottom plates and the forward bars to the main hoop at the same time. A little weld on each bottom plate, a little weld on the forward bar joint, then a little time to let things cool off. Then repeat. 7. Leave time for welds to cool completely between steps. This can seem long and tedious and it's REALLY hard to slow down and take your time. Ideally you'll have 30m of welding time spread out over 1.5-2h. More cooling time reduces the risk of warping the car and you can't let it cool too much. The times I just mentioned allow the welds to cool at the rate of 2-3m cooling for each minute of welding time. 8. Read #5 again. Good installs require good prep. The quality and success of your install ALL happens before you pick up the welder. Good luck. (IMG:style_emoticons/default/welder.gif) Attached image(s) |
ottox914 |
Nov 28 2010, 10:30 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
McMark: waddya think of this? The 914T currently has the Brad Mayeur heavy duty outer long kit installed. It was not installed to repair ANY structural rust or rot to the longs, I added it to a solid car to keep it that way. IF I was to add your rollbar kit, would the car be stiff enough that I could remove the box sections that run between the center tunnel and the outer sill that the seats mount to? I've been thinking I'd like to put some after market seats in, and retain the seat slider/tilt system that is in the car now, but would need to mount it flat to the floor to fit a non-914 seat. In my car pics you can see the OMP seat I have in the car on the driver side. I made some flat adapters to fit the seat to the oem sliders, and when I'm in the car with my helmet on, I am above the windshield with the top of the helmet. I'd like to put in 2 matching seats, and mount them lower. I was thinking of a full autopower style cage, but had concerns on the street. Your cage could be one solution to consider.
What does anyone think? With Brads outer kit already installed, and if I were to add McMarks rollbar, would adding the engman kit add much more strength? I could easily have a weld-a-thon one weekend and do the engman and the roll bar... ...and, what would you need to do for a replacement back pad- go over the metal firewall directly, or leave the insulation panel glued on and go over that? Attached image(s) |
McMark |
Nov 28 2010, 11:44 PM
Dave,
I think the cross-bar under the seats is of little structural value. I think it's partly to provide a support for the seats, and partly to brace the floor pan. Check out post #50 of this thread where horizontally-opposed modified the beam for the same purpose as you. If I were doing the modification, I would go this route. That way the floor pan retains some support. Moving the beam forward would also accomplish the same. You cannot lower the seat and keep the tilt feature. The 'teeth' that lock the height adjustment are part of what makes the cross-beam so tall. To get height adjustment you would need to fabricate something custom. I would also think that you'll get the best results by getting rid of the seat hinges. I think this GT half-cage would marginalize the Engman kit. If you're looking for every last scrap of stiffening, then you could do both. Because you can't use the stock backpad, a bare firewall or a carpeted firewall would be the only solution. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:31 AM |
