New GT Half Cage, limited availability, build to order |
McMark |
Nov 28 2010, 12:20 PM
I'm got a tubing bender to make a replica GT half cage for a customer car. This is the style of bolt in cage used on some of the GT cars pictured on Armando's AWESOME GT site, as well as the style used in the PMB GT.
Material is mandrel bent 1.75" DOM 0.95", notched and will be completely welded. Plates are laser cut steel, ensuring they look great and fit perfectly. You will be required to weld the provided receiver plates onto your longs. These cages will keep the seats from moving all the way back because of the center brace bars. I have some ideas that will adapt the cage to work better with stock seats. PM me for details. Also, these cages will obviously not work with a stock backpad, nor the door handle/pocket. Each cage will be $xxx in bare steel, with powdercoating available. Shipping is possible, we're probably looking at crate and freight shipping, which should be around $175 (give or take $25). Cages are built to order. --Optional Item 1-- Leave off the two bars going to the center hump. This would let you keep the backpad and knock $xxx off the price. --Optional Item 2-- Leave off the forward/door bars. These add a lot of rigidity, but make getting in and out of the car harder. Leave these off and knock $xx off the price. Custom alterations are also available at full shop rate of $125/hr for actual time spent beyond the building of the standard cage. These cages are now special order. Contact me for details. Installation Info: 1. Use a jack on both sides of the car, in the middle of car (between the wheels) with slight pressure simply to counteract the weight of the car. If you think about the way the weight is distributed, it's split between four wheels roughly equally. You're using the jack to try and distribute the weight six ways evenly. If you lift too much in the middle, you're changing the bias. This is not an exact science or setting. You just have to use your best judgement. 2. Test and measure the door gaps and opening closing effort before and during the welding process. Also measure between the targa bar and the windshield hoop, using the attached picture. Anything within 2-3mm is considered correct. But keep checking that measurement as you weld to make sure things aren't moving. 3. Do not run a bead longer than 1" ever on any joint. Long continuous welds are how cars get warped. 4. If you're using the bolt-in setup, weld the base plates in while they are bolted to the cage. Welding the base plates with the cage fully assembled ensures that everything lines up. 5. Get the cage to sit correctly, fully assembled, before fully welding a single piece. You cannot adjust things as you go. Get them all lined up, sitting flat, etc before you start permanently attaching things. 6. Tack weld the forward bars to the main hoop first, but fully weld the rear bottom plates first. Then weld the forward bottom plates and the forward bars to the main hoop at the same time. A little weld on each bottom plate, a little weld on the forward bar joint, then a little time to let things cool off. Then repeat. 7. Leave time for welds to cool completely between steps. This can seem long and tedious and it's REALLY hard to slow down and take your time. Ideally you'll have 30m of welding time spread out over 1.5-2h. More cooling time reduces the risk of warping the car and you can't let it cool too much. The times I just mentioned allow the welds to cool at the rate of 2-3m cooling for each minute of welding time. 8. Read #5 again. Good installs require good prep. The quality and success of your install ALL happens before you pick up the welder. Good luck. (IMG:style_emoticons/default/welder.gif) Attached image(s) |
brant |
Nov 29 2010, 04:30 PM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The safety devices company have a couple of different styles.
and their Euro sold version of a bolt in kit, did have the fire-wall V style of mount similar to the Mark's design. I used to have one too. I think its VERY nice looking this is taking the thread off topic, but I personally feel the seat mount bar does provide structural rigidity and structural boxing to the chassis. I cut mine out once on my black car, but within months added it back. I think there is some structural purpose and more importantly I think it is a big safety factor for side impact. I also modified my safety devices bar to add a cross brace down low behind the seats from side to side. I have seen a 914 hit in a T bone accident on the race track the car was hit at the driver side seat area and moved inward about 12 inches. This is scary, because your shoulder is only about 6 inches from the outside shell of the door. imagine taking a direct metal impact into your shoulder from a 3000lb moving car? so I think the rear side to side bar is important for safety or racing, and the seat mount cross brace is a small nod towards side impact safety from the factory. The factory long moves inward very easily in a metal to metal contact. buy a different seat if you need head room the ultra shield seat will mount nicely on the floor behind the stock cross brace.... my old scheel seats mounted on the stock sliders/stock cross brace and were low also. 2cents nice roll bar Mark! brant |
Madswede |
Nov 30 2010, 02:25 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
buy a different seat if you need head room the ultra shield seat will mount nicely on the floor behind the stock cross brace.... my old scheel seats mounted on the stock sliders/stock cross brace and were low also. 2cents nice roll bar Mark! brant Thanks for your $0.02 Brant. I was considering this but I'm afraid it will make the car too uncomfortable for longer drives and I'm worried about leg room as well as head room - I guess I could always use cardboard seats. (IMG:style_emoticons/default/laugh.gif) - Nelson (a shade under 6'3" and 240# for those that don't know me) |
Lo-Fi Version | Time is now: 17th May 2024 - 10:13 AM |
