914 at Pick n Pull Newark Ca 5-18-13, R I P vin # 4742917508 Black |
Michael N |
May 2 2011, 10:34 PM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I didn't see the car. I just saw it was newly posted on thier site.
mikey63 |
May 3 2011, 08:11 AM
Member Group: Members Posts: 121 Joined: 30-March 10 From: Windsor,Ca Member No.: 11,529 Region Association: Northern California |
I checked out the car and got some decent stuff of it. The doors look good as well as as the glass. No engine but it did still have a side shift trany.The car is a 1970.
Check out the pics. I will add this to the data base. Attached image(s) |
Sleepin |
May 3 2011, 09:38 AM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Wow! Someone cut off that DS rear quarter for me?
QUOTE |
Root_Werks |
May 3 2011, 10:03 AM
Village Idiot Group: Members Posts: 8,305 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Somebody should grab that steering wheel hub adapter. Those are getting hard to find.
Krieger |
May 3 2011, 10:28 AM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I saw that. Does that fit early only? What wheels bolt up?
GaroldShaffer |
May 3 2011, 11:24 AM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Yep, only fit the early cars. Also need to grab the rear hubs (or complete trailing arm) because they were also bossed to be drilled for 5 lug if going on a /6.
Grab the steering column (early cars only), silver button guages, the good fog light (if lense has a line going across 1/3 of the way from bottom it is the correct lense for 70-early 72 models. The lense style, not shape, changed on mid 72 -74 cars) fog light switch, lower & upper dash pads (here again different than later model 914), outside door handles, inside door handles with surround (later had black plastic surrounds), glove box & door (again different than on later style cars) |
Krieger |
May 22 2011, 09:59 PM
Today I was able to get the winshield out of this car and home without breaking! This car has adjustable Koni shocks in the front. They felt stiff.
Michael N |
May 19 2013, 06:48 PM
Attached are pictures as the car was on 5/19/13. Vin # 4742917508. Black L041. Still had the 1.8 l jet injected engine and side shift transmission with shift rod.
I forgot to check the build date. Black 74 and I didn't take time to look for the yellow markings of a Bumblebee. It did have sail panel vinyl and chrome sail panel trim. I doubt it was a LE bumblebee. Attached thumbnail(s) |
Michael N |
May 19 2013, 06:49 PM
type47fan |
May 20 2013, 12:45 AM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Is it just the angle or do those steel wheels look wider than usual? If i'm not mistaken, those only came in 5.5" ... (IMG:style_emoticons/default/idea.gif) Good eye, Andy! For a short time, I had similar wheels on my 1972 914. I got them from from a 1973 VW Sports Bug. They were described as Lemmerz VW steel sport wheels, 5.5J x 15, offset code ET34. The skinnier Lemmerz 4.5J x 15 steel wheel has offset code ET41. The width & offset are stamped into the front of the wheel center, between the lug bolt holes. |
Lo-Fi Version | Time is now: 25th April 2024 - 01:46 AM |
