Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> 999.166.017.02, EBrake Cable Clips (at trailing arm)
McMark
post Nov 29 2010, 10:10 PM
914 Freak!
These clip the e-brake cables onto the trailing arm.
These clips are stamped from steel (likely spring steel) and are coated in yellow zinc / cad. The 'fingers' should have a slight bend in them to help hold tension.
OD: 20.5mm
Thickness: 0.75mm
(IMG:http://www.914world.com/bbs2/uploads/post-419-1291089988.jpg)
- Lo-Fi Version Time is now: 1st July 2025 - 01:48 AM
