Rubber fuel line size |
patssle |
Dec 2 2010, 04:22 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I have an 8 mm fuel line from Tangerine with the end beads and 40IDA Weber carbs. For some reason the fuel connector doesn't list the size on websites. What is an appropriate rubber fuel line size to connect to the 8mm line and the webers? If I need two different sizes that is fine.
I've seen people mention using American standard system fuel lines, on these metric parts? |
Lo-Fi Version | Time is now: 19th May 2024 - 02:42 PM |
