Out with the old...in with the new...Britain's Racecar Development, Subaru Engine, Lotus Suspension! Time to go racing! |
Britain Smith |
Dec 6 2010, 11:33 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
Britain Smith |
Dec 6 2010, 11:38 AM
From this weekend.
First order of business was rerouting the water coolant lines coming off the waterpump housing. The Outfront Motorsports bracket interferes with the stock routing of the heater hardline and the line that goes to the coolant reservoir tank was pointing in the wrong direction after it was relocated. Therefore I got some extra hardlines and starting cutting and welding away. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291657137.1.jpg) Here is the pipe off the back of the water cross-over pipe. I am obviously bypassing the heater core but that line was interfering with the bulkhead. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291657137.2.jpg) Fab'ed up a small bracket to secure the Turbosmart FPR to the intake manifold. Had to order some additional AN fittings for the fuel line routing $$ (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291657138.3.jpg) Finally got started on the exhaust downpipe routing. Here is the front section, however I still have to stuff two wastegates in here. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291657138.4.jpg) Here is the routing down the length of the car. You can also see the bracket I made to secure the Coast Fabrication Muffler. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291657138.5.jpg) This muffler weighs less than 5lbs. This one was scuffed a bit so I got it less than half off...gotta love the scratch and dent sales. I sure hope it is quiet enough to pass sound regulations...if not, I might be adding another. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291657138.6.jpg) Got to get some additional flanges cut at the waterjet place today and then I can finish up the wastegate routing. -Britain |
Lo-Fi Version | Time is now: 17th May 2024 - 07:31 PM |
