Out with the old...in with the new...Britain's Racecar Development, Subaru Engine, Lotus Suspension! Time to go racing! |
Britain Smith |
Dec 6 2010, 11:33 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
Britain Smith |
Dec 6 2010, 11:34 AM
I purchased the Synic Motorsports header which is equal lenght, but not exactly for a twin-scroll set-up.
(IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656847.1.jpg) With the header installed on the engine, you can see the engine mounts that I am utilizing for the conversion. They are actually for a Vanagon conversion, but with a little modification they fit just fine. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656847.2.jpg) Back to the header...the first order of business was chopping off the pipes right after the merge collectors...getting closer to a twin-scroll set-up. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656848.3.jpg) The only problem was that when I cut off the pipes, I was faced with a failed attempt at properly building a header. The merge collectors were not the highest quality that I have seen. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656849.4.jpg) Little bit of time with the die grinder and they look much more acceptable now...and I bet the flow better. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656849.5.jpg) Ok, now with the header mounted you can see my thinking on the positioning of the turbo. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656850.6.jpg) With the engine back in the car and everyone suspended with straps, you can see how the turbo will fit just perfectly in the factory recessed firewall location. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656851.7.jpg) To get the turbo in the correct orientation, I had to re-clock the compressor side. To do this, I took off the small retaining bolts/clips, applied a little heat and some motivation from a mallet and it popped right off. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656851.8.jpg) |
diggatron |
Dec 7 2010, 01:40 PM
Newbie Group: Members Posts: 3 Joined: 6-December 10 From: Wichita, Kansas Member No.: 12,461 Region Association: None |
Can I ask where one might be able to get this Vanagon Engine mount?
With the header installed on the engine, you can see the engine mounts that I am utilizing for the conversion. They are actually for a Vanagon conversion, but with a little modification they fit just fine. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-364-1291656847.2.jpg) |
Britain Smith |
Dec 7 2010, 02:47 PM
diggatron |
Dec 7 2010, 10:13 PM
Thanks, Britain! I haven't picked my '14 up yet, but that will happen this week... Just making the rest of the plans! |
dlo914 |
Dec 8 2010, 12:50 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
Thanks, Britain! I haven't picked my '14 up yet, but that will happen this week... Just making the rest of the plans! Brit, how much were the brackets? |
Lo-Fi Version | Time is now: 21st May 2024 - 09:46 PM |
