Out with the old...in with the new...Britain's Racecar Development, Subaru Engine, Lotus Suspension! Time to go racing! |
Britain Smith |
Dec 6 2010, 11:33 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
For those who don't know me or the car, I have a '74 914 that is a dedicated AX car. It previously had a high compression 2.7 6-cylinder motor and made 205hp/205ft-lbs at the wheels. This set-up wasn't all that bad considering that it won the 2008 and 2009 914 Shootout events, however the quest for more speed continues.
Here is the car in the 2010 season trim. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1291656786.1.jpg) I have recently sold the 2.7L 6-cylinder engine and all the remaining 914/6 conversion parts. I have used the proceeds to fund the conversion to Subaru power. Now most would say that a Subaru conversion can be done on a budget, however I have found that the money goes flying out the window when doing something like this. Regarding the engine...logical choice would be to go for a EJ257 2.5L USDM STi engine. However, all the SCCA rules for AX are built around displacement which in turn dictates the minimum weight. Therefore, I have gone with a JDM STi version8 Spec-C engine which is a 2.0L, twin-scroll, hand ported/polished, 8500rpm animal. I will get slightly less hp and torque numbers than the 2.5L, but save 150lbs of weight. |
Britain Smith |
Dec 20 2010, 09:09 PM
The mounting points have rubber isolators, the radiator is not hard mounted.
-Britain |
JRust |
Dec 21 2010, 12:26 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
The mounting points have rubber isolators, the radiator is not hard mounted. -Britain I figured I should have kept my mouth shut (IMG:style_emoticons/default/sad.gif) .You do everything so nice I should have known. I just didn't see them. Conversion is looking great (IMG:style_emoticons/default/piratenanner.gif) |
Britain Smith |
Dec 21 2010, 02:46 AM
The mounting points have rubber isolators, the radiator is not hard mounted. -Britain I figured I should have kept my mouth shut (IMG:style_emoticons/default/sad.gif) .You do everything so nice I should have known. I just didn't see them. Conversion is looking great (IMG:style_emoticons/default/piratenanner.gif) No worries Jamie...feel free the chime in anytime. -Britain |
Lo-Fi Version | Time is now: 17th May 2024 - 07:13 PM |
