brake question from a newbie..., my search didn't answer my question.. |
red914 |
Apr 23 2004, 07:36 PM
...i believe in coyotes and time as an abstract... Group: Members Posts: 862 Joined: 8-February 04 From: poulsbo, washington Member No.: 1,641 |
first i will try to describe the problem in a meaningful way. i have newer calipers in the rear (from PO). the right rear has developed a drag problem. it does not seem to release, and hence, drags, heats up, etc. I have tried to decipher the haynes manual, but to no good result. does the brake proportioning valve have anything to do with this? how does one adjust the venting? i messed with that a bit, but the allen screw and lock nut allwo brake fluid to seep out of from arond them when screwed in, and only seem to tighten up when run out. none of which, by the way, effects the drag at all.
i realize this is a rambling question, but i am in over my head at this point. any knowledge out there? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:24 PM |
