How to resize images in Windows 7? |
Dec 8 2010, 04:01 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Alright,
here is one way to do it that I found worked. 1--Open the picture with MSPaint (windows version 7) 2--Click on the upper menu to resize the image 3--Click on Pixels and maintain ratio should be checked 4--In the upper portion of the pixels, remove whatever number is in there and type 640...the lower one should go to 480 automatically if you left ratio checked. 5--Save AS a gif file (accept the "error" and warning that you will lose resolution) 6-using Save As again, go save the same pic as a JPG file. (you are now re-saving the GIF file, not the original JPG file, so rename it) I was able to take a 1.7 meg pic and reduce it to 133kb by doing that process. I will try PNG to see if that works also. Rich |
Dec 8 2010, 04:06 PM
I tried leaving the file at the same size and saving as a PNG which resulted in increasing the file size to 3.8 Megs.
I then tried the identical process as above but instead of saving as a GIF, I saved it as a PNG, but smaller. That resulted in the file size of 806kb. So, that process does not comply with our 500k size limit per post. Rich |
Andyrew |
Dec 8 2010, 05:11 PM
Ifranview.....
One step. (ok, like 3... but still) |
etcmss |
Dec 8 2010, 05:42 PM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
tried this method from samba? re-sizing works well there and here
http://www.thesamba.com/vw/forum/viewtopic.php?t=51 |
nathansnathan |
Dec 8 2010, 06:36 PM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
gifs are good for logos graphic images because their file size is based on # of colors used. Jpgs are the ideal format for photos with filesize in mind... until WebP becomes more common at least.
okieflyr |
Dec 8 2010, 06:41 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Rich,
This topic came up awhile back, and someone suggested this: http://prish-image-resizer.software.informer.com/ I have found it to be simple like the power toys for my old XP, and have not had any issues with it over the last year. It has to be simple or I won't figure it out.... I miss my XP (IMG:style_emoticons/default/sad.gif) |
Richard Casto |
Dec 8 2010, 07:05 PM
GaroldShaffer |
Dec 15 2010, 07:44 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Matt Romanowski |
Dec 16 2010, 08:14 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Richard Castro your my hero. That is awesome.
Richard Casto |
Dec 16 2010, 12:39 PM
siverson |
Dec 16 2010, 05:01 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I amazes me how stuff like this is still so complicated.
Here is a tool a wrote about a year ago that I'm been meaning to add some more features to, but it works pretty well as-is. If you want to try it, go for it and let me know how it works. http://diomedestorage.com/downloads.aspx#uploader Once you've created an account and have the application running, you just select your photos and press SHIFT-CTRL-C (like CTRL-C/copy but with the SHIFT key too). It will: (a) resize the images (set under Options->Resize Images), ((IMG:style_emoticons/default/sunglasses.gif) upload them to a server (Diomede Storage), © and copy the new links to your clipboard. Then you can just paste the links anywhere (like here). For example: http://dio314.diomedestorage.com/dl/TYF6TN...VA/IMG_0889.JPG Or wrap that URL in tags like this: (IMG:http://www.914world.com/bbs2/uploads_offsite/dio314.diomedestorage.com-654-1292540469.1.JPG) -Steve |
Elliot Cannon |
Dec 17 2010, 01:19 AM
This is the only one I know how to use. http://pixresizer.software.en.softonic.com...CFQk5gwodUTLfpA
balljoint |
Dec 17 2010, 01:26 AM
Prish resizer. Just right click on your image, same as in XP.
Lo-Fi Version | Time is now: 2nd May 2024 - 12:27 AM |
