> not getting enough fuel pressure. Whats up?, Fuel pump??
RFoulds
post Dec 8 2010, 04:06 PM
914Rennsport
having an issue with fuel pressure. Fuel flows freely from the end of the tunnel lines, connecting to fuel pump. (its a 74 1.8 with stock FI)
fuel pump has been thoroughly checked out and seems to be good. But, fuel pressure is not enough to get a squirt out of the injectors. Instead, while cranking, the fuel is barely dripping out instead of a good spurt.
all fuel lines are new, injector rails are good, injectors all good.
Any ideas what is causing this??
r_towle
post Dec 8 2010, 04:15 PM
Custom Member
The pump shoots it out at something like 60PSI.
The regulator (which is a rising rate regulator on Ljet) reduces it to ~30 PSI)
Bernoulis principle keeps the whole system, the whole loop at the same pressure based upon what the regulator is set at...its a physics thing...but its true none the less.
Put a real fuel gauge (a test gauge) inline both before and then after the regulator to see what is happening.
The regulator is on the drivers side inline just beofre the injectors in the fuel route/fuel lines and its bolted to the head tin near the rear of the engine bay.
It could just be a dying regulator...might be time for replacement.
They are adjustable if you turn the bolt, but you need a gauge setup after the regulator (between the regulator and the fuel pump on the return line) to know what you are setting it to.
If you want to figure out the plumbing...there are two little bolts in the metal fuel rail that are specifically for hooking up a fuel pressure gauge...I have yet to find, or bother to find, the plumbing to get my gauge plumbed into that little itty bitty hole....but its there for this test.
I have a fuel pressure gauge with two 3 inch hoses on it, and two barbed fittings on the ends of those...I can slip it inline on most any car pretty quick..
Standard FLAPS diagnostic tool if you go down that isle.
Rich
sfrenck
post Dec 8 2010, 04:21 PM
Had similar issues a while back
Everything Rich just said +
-Check the fuel filter. Old/dirty or backwards (ask me how I know that one) can cause a large pressure drop on the system.
-Make sure your pump is piped correctly
Scott
pcar916
post Dec 8 2010, 04:37 PM
Is that a Lola?
If you block the return line and your fuel pressure goes up beyond normal the regulator is bad. But only do it for a moment or two.
ConeDodger
post Dec 8 2010, 04:55 PM
Apex killer!
Ground? On the '75 the fuel pump has its own ground, under the fuel tank just under the driver side of the tank...
- Lo-Fi Version Time is now: 9th July 2025 - 08:26 AM
