911 9146 engine fan housings, Possible Mismatch?? |
bcheney |
Dec 12 2010, 09:03 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
My conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
Attached image(s) |
sixnotfour |
Dec 12 2010, 10:48 AM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE If I remember correctly the later housings are too deep; you can machine some off the back. Yes too deep , therfore you need a spacer or correct alternator. its the early (901) that you need to machine deeper for a late alternator. here is a thread right here; http://www.914world.com/bbs2/index.php?s=&...st&p=669398 |
bcheney |
Dec 12 2010, 11:35 AM
Do you know what could be used as a spacer if I decide to utilize the 930 numbered housing with the 55 amp alt? What would the exact height of the spacer be? Thanks for the help.
Lo-Fi Version | Time is now: 4th May 2024 - 01:28 AM |
