911 9146 engine fan housings, Possible Mismatch?? |
bcheney |
Dec 12 2010, 09:03 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
My conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
Attached image(s) |
rfuerst911sc |
Dec 12 2010, 03:44 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Brian I believe the proper count of shims is seven. You might want to put 7 under the pulley to see what it looks like. In regards to how thick of a spacer just put a straight edge on the face of the crank pulley and measure the distance to the alternator pulley.
Lo-Fi Version | Time is now: 4th May 2024 - 02:46 AM |
