911 9146 engine fan housings, Possible Mismatch?? |
bcheney |
Dec 12 2010, 09:03 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
My conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
Attached image(s) |
sixnotfour |
Dec 13 2010, 03:34 AM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Shim count
Attached image(s) |
bcheney |
Dec 13 2010, 06:52 AM
As usual...thanks for all the replies everyone. You guys are the best. I am going to search a stash of mine to see if I have a 901 housing...that would solve the problem. Otherwise I will look into producing some 9.5 mm spacers to compensate.
Mark Henry |
Dec 13 2010, 08:07 AM
As usual...thanks for all the replies everyone. You guys are the best. I am going to search a stash of mine to see if I have a 901 housing...that would solve the problem. Otherwise I will look into producing some 9.5 mm spacers to compensate. On the housing measure the depth of where the alternator seats in the inner ring. I was wrong about the half inch, it's closer to .400 deeper on the one ring I have. This is about the same as your 9.5mm figure so you have the wrong alternator or housing, you have to swap one of them out. Just adding a 1cm spacer to the pulley end is a bad idea, the pulley nut will nothing left to grab onto. Last thing I'd want is to have only a couple of threads holding my pulley and fan on. Putting shims under the alternator might be sketchy as well. BTW both of the the housings I have are the same 901 part number even though the alt mount depths are different. |
Lo-Fi Version | Time is now: 4th May 2024 - 02:35 AM |
