911 9146 engine fan housings, Possible Mismatch?? |
bcheney |
Dec 12 2010, 09:03 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
My conversion is using an original 9146 case. I am using a 911 fan housing and 55amp Bosch Alternator. I have assembled and I'm not sure if I have a problem. See pics. Belt doesnt seem to align properly. I have 5 shims under and 1 shim on the outside. I'm wondering if the housing that I'm using may be a problem as it is from a later model car. Housing number is 930106102OR and you can see it on the second pic.
Attached image(s) |
Mark Henry |
Dec 14 2010, 07:25 AM
So how many amps on the smaller Bosch alternator?
It will be the one I'm going with, the deep housing I have is junk. |
bcheney |
Dec 14 2010, 07:40 AM
55 amp Bosch alt. uses the shallow housing...5mm mount depth. Your fan and outer pulley should have 8 holes in it (just like the one in post #12 twelve above).
Lo-Fi Version | Time is now: 4th May 2024 - 09:51 AM |
