FS: Heat Tube, * Featured Item * |
914werke |
Oct 6 2016, 04:29 PM
"I got blisters on me fingers" Group: Members Posts: 9,894 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Resurrection...
1 still available (IMG:style_emoticons/default/smile.gif) |
Dion |
Oct 6 2016, 04:59 PM
RN Group: Members Posts: 2,754 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Rich you have a pm.
euro911 |
Oct 7 2016, 12:36 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'm not planning to cut my longs open, so hopefully, the two rubber plugs on the inside of each long will allow adequate access (IMG:style_emoticons/default/unsure.gif) |
914werke |
Oct 7 2016, 02:01 PM
I'm not planning to cut my longs open, so hopefully, the two rubber plugs on the inside of each long will allow adequate access (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/huh.gif) Oh you mean the Tar ovals glued to the recessed holes? Perhaps ...its tight in there the tube is held in by spring steel clamps of sorts. Ive tried removing them from one end or the other but as I said their in there tight. BTW Ive got replacement tar oval plugs for those concours guys. (IMG:style_emoticons/default/smile.gif) @ Dion back at you. |
Dion |
Oct 7 2016, 03:04 PM
Thanks Rich
euro911 |
Oct 7 2016, 03:05 PM
I'm not planning to cut my longs open, so hopefully, the two rubber plugs on the inside of each long will allow adequate access (IMG:style_emoticons/default/unsure.gif) Perhaps ...its tight in there the tube is held in by spring steel clamps of sorts. ... Are the 'tar-ovals hard to remove? |
914werke |
Oct 7 2016, 03:21 PM
ya after 40 years they tend to crumble to pieces rather that come off intact.
914werke |
Dec 8 2016, 11:16 AM
914werke |
Jan 23 2018, 01:28 AM
euro911 |
Jan 23 2018, 01:42 AM
I may just drill some small holes in the bottom of the curvy section to insert the wand to spray the Eastman internal frame coating (IMG:style_emoticons/default/idea.gif) |
914werke |
Jan 23 2018, 12:18 PM
Mark that is the inside Pass long .5 The OE part. NLA that I am aware.
The equivalent is now only available as two pieces. The straight section that is crap & the repop curved section at the back, that should be a lapped part but isnt available currently with its "top" layer like the OE part. I posted the pic for someone (you?) who asked about how the tube is attached. |
914werke |
Mar 13 2018, 11:47 AM
Mblizzard |
Mar 13 2018, 01:42 PM
I may just drill some small holes in the bottom of the curvy section to insert the wand to spray the Eastman internal frame coating (IMG:style_emoticons/default/idea.gif) I used the holes that there for the bottom seat belt bolt and the rivet holes used to hold on the threshold plates. I had a vey long plastic straw (like on a WD-40 can) that I was able to adapt to the Eastman can. Could not verify how well it was coated but I did get a lot in! |
914werke |
Sep 6 2018, 12:06 AM
914werke |
Oct 12 2018, 09:54 AM
Oct 12 2018, 10:10 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
maybe try the earlySregistry if they are the same as early 911.
914werke |
Oct 13 2018, 02:57 PM
You probably see the inside of 911 longs more than I. Didn't know they used the same part but make sense.
914werke |
Apr 11 2019, 09:30 AM
914werke |
Feb 1 2020, 04:49 PM
Still have a couple of these available.
For reference RD sells repop versions of these for $112 +ship Bargain! (IMG:style_emoticons/default/first.gif) |
914werke |
Apr 29 2020, 12:36 PM
Lo-Fi Version | Time is now: 29th March 2024 - 01:09 AM |
