| damnfiknow |
Dec 28 2010, 09:12 PM
Member ![]() ![]() Group: Members Posts: 77 Joined: 25-October 09 From: Texas Member No.: 10,980 Region Association: None |
Someone, please, the equation for determining the diameter of a bellcrank to be used on a Weber 40 setup. Standard 914 accelerator cable length/throw (full close/full open) and standard Weber 40 butterfly. Also, anyone know of a source for such a bellcrank? Hope not to have to farbricate one myself. No lathe so will have to be with an electric drill for turning power. Extremely primitive.
| McMark |
Dec 28 2010, 09:17 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
The absolute best bellcrank I've seen is this one from CSP.
It's extremely rugged. Really, really well built. And even uses ball bearings for the rotation. Such a great product and worth every penny. |
| biosurfer1 |
Dec 28 2010, 10:01 PM
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I have the one Mark pointed out and I like it. It's easy to adjust and will even work if you install it incorrectly...ask me how I know:/
| mrbubblehead |
Dec 28 2010, 11:15 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
The absolute best bellcrank I've seen is this one from CSP. It's extremely rugged. Really, really well built. And even uses ball bearings for the rotation. Such a great product and worth every penny. do you have any pics of it installed? |
| McMark |
Dec 29 2010, 01:10 PM
I sure do!
| jeffdon |
Dec 29 2010, 01:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I sure do! So in this setup, it appears that both rods link to the carbs at the BACK of the carbs. My carbs are absolutly identical, which means the rod attachments are at the front of one carb, the back of the other. My bell crank is homebrew and designed to accommodate this. I have a hunch that it does not pull equally on both carbs. anyone care to comment on the viability of my set up? Don't hate on the general condition of the rest of the engine bay, I have cleaned it up since i took the pic. ![]() |
| mrbubblehead |
Dec 29 2010, 01:32 PM
| Mike Bellis |
Dec 29 2010, 02:16 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I sure do! do you think this is a better setup than the hex linkage from cb performance? I had a type 1, full race 1776 that I used to drag race. I had the hex linkage come off many times due to wheel hop. Always at the pivot points. I've never tried this bell crank but I have made my own in the past. I would lean to the bell crank over the hex. |
| mrbubblehead |
Dec 29 2010, 02:23 PM
I sure do! So in this setup, it appears that both rods link to the carbs at the BACK of the carbs. My carbs are absolutly identical, which means the rod attachments are at the front of one carb, the back of the other. My bell crank is homebrew and designed to accommodate this. I have a hunch that it does not pull equally on both carbs. anyone care to comment on the viability of my set up? Don't hate on the general condition of the rest of the engine bay, I have cleaned it up since i took the pic. ![]() seams like i had a single 4o idf setup on a center mount type 1 offroad car. the carb i had had the throttle pull on the wrong side. FAT performance had the arm to allow me to put it on the other side of the carb so i could use it. but if your linkage is working well, it might not be worth the change. reread your post. its not working well. call FAT. if i remember right, the arm is different, so you cant move it front to back. but check to make sure. maybe it was the arm on MY carb that wouldnt work. |
| SirAndy |
Dec 29 2010, 02:24 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,479 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My carbs are absolutly identical, which means the rod attachments are at the front of one carb, the back of the other. Just switch the attachment on one of your carbs so they both attach in the rear ... (IMG:style_emoticons/default/shades.gif) |
| ConeDodger |
Dec 29 2010, 02:34 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,426 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
The absolute best bellcrank I've seen is this one from CSP. It's extremely rugged. Really, really well built. And even uses ball bearings for the rotation. Such a great product and worth every penny. Is this what I should be using for my Jenvey's Mr. McMark? |
| mrbubblehead |
Dec 29 2010, 02:39 PM
I sure do! So in this setup, it appears that both rods link to the carbs at the BACK of the carbs. My carbs are absolutly identical, which means the rod attachments are at the front of one carb, the back of the other. My bell crank is homebrew and designed to accommodate this. I have a hunch that it does not pull equally on both carbs. anyone care to comment on the viability of my set up? Don't hate on the general condition of the rest of the engine bay, I have cleaned it up since i took the pic. ![]() it looks like the parts in the csp link comes with the arms for the carbs so you may not need anything extra (IMG:style_emoticons/default/biggrin.gif) |
| anderssj |
Dec 29 2010, 02:43 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
The absolute best bellcrank I've seen is this one from CSP. It's extremely rugged. Really, really well built. And even uses ball bearings for the rotation. Such a great product and worth every penny. Looks VERY nice! CSP's web-site says the linkage fits Weber IDFs, but no word on Dellorto DRLAs. I'm thinking that if CB Performance hex linkage fits both, then the CSP should too. Anyone using this on Dell's? Thanks! Steve A- |
| Cevan |
Dec 29 2010, 03:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Let me see if I can remember how I did mine. If I recall, the sweep of the IDF's butterfly is 78 degrees. I measured mine. Then I measured the amount of cable taken up by the gas pedal (with the adjuster at about the mid-way point). The circumference of a pulley needed to pull the right amount of cable is the length of the cable throw divided by (78/360). The radius of the bellcrank or in my case, the pulley is the circumference divided by 2*pi.
So if the gas pedal took up 2 inches of cable, then the circumference is 2/(78/360)=9.2 inches. The radius of the pulley=9.2/2*pi=1.47 inches. So the diameter would be 2.94 inches. ![]() |
| McMark |
Dec 29 2010, 03:49 PM
I have a hunch that it does not pull equally on both carbs. anyone care to comment on the viability of my set up? Unequal pulling/pushing is unacceptable. You should be able to adjust your carbs so that they hit WOT at the same time and flow the same volume of air at idle. I'm a fan of home built stuff, but you gotta be 100% accurate with this type of thing or you're engine may not run smoothly or you may be tossing money away in wasted fuel. A carb linkage should have ZERO slop or wobble. It should move both carbs equally, and it should be simple. do you think this is a better setup than the hex linkage from cb performance? 100% better. I will NEVER recommend hex linkages again. They are all horrible. Is this what I should be using for my Jenvey's Mr. McMark? I think so. (IMG:style_emoticons/default/sunglasses.gif) CSP's web-site says the linkage fits Weber IDFs, but no word on Dellorto DRLAs. I'm thinking that if CB Performance hex linkage fits both, then the CSP should too. Anyone using this on Dell's? It looks like they'll work. |
| azbill |
Dec 29 2010, 05:57 PM
Member ![]() ![]() Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
Take a look at the Sidewinder bell crank designed for the Type IV engine. I use this on my Jenvey throttle bodies works perfect. every time all the time Yes I make them and sell them. Check the vendors section.
| 914werke |
Sep 12 2019, 05:21 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,647 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
@mcmark In the example pic you provided it appears the angle of the T-cable comes from the front of the engine rather than the R side like OE?
Did you find its necessary to reroute due to cable length or bracket placement? |
| johnhora |
Sep 12 2019, 09:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 902 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
Source for the CSP Mark mentioned...
https://www2.cip1.com/ProductDetails.asp?Pr...129%2D941%2D400 out of stock at the moment but they get more all the time. |
| porschetub |
Sep 13 2019, 01:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,091 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
| porschetub |
Sep 13 2019, 01:29 AM
Source for the CSP Mark mentioned... https://www2.cip1.com/ProductDetails.asp?Pr...129%2D941%2D400 out of stock at the moment but they get more all the time. I heard they are no longer being made in the 914 application (IMG:style_emoticons/default/confused24.gif) . Been searching for a customer for sometime,plenty in the UK but the shipping is mental for me. |
Lo-Fi Version | Time is now: 1st May 2026 - 01:26 AM |
