> Head studs stuck! Need help removing.
tornik550
post Jan 2 2011, 03:56 PM
Note- yes, I realize this has been covered in previous posts however I am looking for additional info.
I recently acquired several new cases for my rebuild. I am trying to remove the head studs. I have an EC case, a EA case and a bus case modified for a 914. I was able to remove the studs on the EC case without major problems however the case has some issues. I do not plan on using the bus case. The EA case seems the best but I can only get 1/2 of the studs out.
I have tried large amounts of penetrating oil over the past few days. I have tried to heat the CASE with a propane torch for about 2 minutes. I am double nutting the stud. I have tried to grip the base of the stud with vise grips however I cannot get the vise tight enough so it doesn't spin (due to some corrosion). I am using a 36 inch wrench so I get very good leverage.
Any ideas? I can put a bit more muscle into removing the studs however I am scared that I will break the stud since it already seems to twist quite a bit. Should I heat the case longer? I have broken a head studs on a EC case in the past and it is not fun trying to remove it (I was actually able to drill the stud out but not fun).
tornik550   Head studs stuck! Need help removing.   Jan 2 2011, 03:56 PM
bcheney   Heat and a proper stud removal tool from (Snap on ...   Jan 2 2011, 05:24 PM
ArtechnikA   Heat and a proper stud removal tool from (Snap on...   Jan 3 2011, 05:03 AM
hcdmueller   I double nutted the studs and used an impact wrenc...   Jan 2 2011, 05:51 PM
Cap'n Krusty   Two minutes with the propane torch doesn't eve...   Jan 2 2011, 06:01 PM
tornik550   Two minutes with the propane torch doesn't ev...   Jan 2 2011, 06:06 PM
sean_v8_914   use a stop watch or the radio as a guide for time....   Jan 2 2011, 06:53 PM
KaptKaos   50/50 Acetone/ATF makes a very good penetrant.   Jan 2 2011, 08:13 PM
cary   Switch to MAPP gas. The yellow tank is quite a bit...   Jan 2 2011, 09:15 PM
Jake Raby   The trick is grippin g at the base of the stud.. O...   Jan 2 2011, 09:16 PM
tornik550   I just came in from working on the head studs. I ...   Jan 2 2011, 10:09 PM
McMark   Use LARGE vice grips. Get them as tight as absol...   Jan 2 2011, 10:34 PM
Cap'n Krusty   Curved jaw channel-locs. They tighten as you put ...   Jan 2 2011, 11:36 PM
Matt Romanowski   Or use a pipe wrench.   Jan 3 2011, 07:06 AM
hcdmueller   Or use a pipe wrench. :agree:   Jan 3 2011, 08:55 AM
Jake Raby   Clamp 3 large pairs of vice grips at the base and ...   Jan 3 2011, 09:17 AM
Vacca Rabite   MAPP heat the case. A lot. Quench the stud with ...   Jan 3 2011, 11:10 AM
ArtechnikA   ...He used Oxy/Acc for heat, not MAPP, but I thin...   Jan 3 2011, 01:00 PM
r_towle   bring the case to the same machine shop you are br...   Jan 3 2011, 08:21 PM
sean_v8_914   mc said a good one. try a little tightening. then ...   Jan 3 2011, 08:34 PM
- Lo-Fi Version Time is now: 13th July 2025 - 10:27 AM
