Help ID Boge Strut, Please. 911-341-079-14 |
913B |
Jan 5 2011, 10:06 AM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Can any please tell me what this Boge Strut came from. Just want to know it will fit my 914 5-lug conversion.
Thanks All ! P/N 911-341-079-14 |
dr914@autoatlanta.com |
Jan 5 2011, 11:46 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
says that that part number has been superceded to a Koni 911s strut 76-77 911 (91134104110) A matching pair will certainly work.
Can any please tell me what this Boge Strut came from. Just want to know it will fit my 914 5-lug conversion. Thanks All ! P/N 911-341-079-14 |
Eric_Shea |
Jan 5 2011, 09:38 PM
Sounds like a 74 Boge strut. Good 914 strut.
913B |
Jan 5 2011, 10:52 PM
Cool, thanks guys for the assist.
-JR- |
Apr 29 2014, 12:27 AM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I need to revive this old thread...
I have the same Boge strut from a complete 911 front end. However the left (911-341-079-14) is bent and must be replaced. I'm trying to determine what a suitable replacement would be. The part number isn't listed in PET6 for some reason. Seems to jump from ...-079-00 to -30. I understand that the ball joint types changed in the 70's some time. Can anyone provide some insight to me on a part # that would be a suitable replacement as no one seems to have one of these anymore? |
-JR- |
Apr 29 2014, 10:53 PM
Delete
-JR- |
delete
-JR- |
Apr 29 2014, 11:04 PM
Update: I've been able to determine that part number 911-341-079-14 is only the strut tube with no spindle.
The complete strut assembly will fall under another part number NOT marked on the strut. It's possible that the strut could be one of several. I'm unsure of the year range that the 911-341-079-14 strut tube was used on, but I can tell you it came on a 75 US 911 clip I bought. I can also tell you that these are the part numbers below possible for a strut tube carrying the aforementioned part number... 911-341-043-01 Left with M caliper (3" caliper mount bolt hole spacing) 911-341-044-01 Right 911-341-043-02 Left with S caliper (3.5" caliper mount bolt hole spacing) 911-341-044-02 Right PET says these came on cars from... 69 --> 77 for the M caliper type 69 --> 85 for the S caliper type So at the end of the day, on a Boge strut measure your caliper mounting holes to determine what type you have. Not sure if there are any veteran 911 guys in the forum to back up what I've found. Have fun guys |
Lo-Fi Version | Time is now: 16th May 2024 - 11:41 AM |
