> Will 2.4 L engine work with stock FI, Will stock FI work with a larger bore engine
reharvey
post Jan 13 2011, 10:25 AM
I'm getting ready to build a 2.0 engine for my latest 914 project. I've put together several of these motors in the past but have always used the Euro type Mahle 94mm pistons. How big of a piston can I use and still retain the FI. I can make minor modification to the FI if need be. I've done this in the past. Has anyone out there try this?
realred914
post Jan 13 2011, 10:28 AM
Group: Retired Members
QUOTE(reharvey @ Jan 13 2011, 08:25 AM) *
ive been told that thebig bore 2056 cc motor (96 mm pistons, stock strck
) is about thelimit for stock 2.0liter d-jet tweeks of the pressure sendor will be required to run the 96mm pistons.
orange914
post Jan 13 2011, 11:09 AM
http://5starmediaworks.com/index.html
NOOOOOOOOOO
orange914
post Jan 13 2011, 11:11 AM
oh (IMG:style_emoticons/default/welcome.png)
2056 with MPS modification is about the limit to a 2.0 d-jet
Chris Pincetich
post Jan 13 2011, 11:19 AM
B-)
Maybe Andy will chime in. He has a very nice red 914 with 2.3 TIV and a tweaked D-Jet FI system. I know he did not build it himself. He uses it for cruising and AX racin and was always happy w it when I saw him (IMG:style_emoticons/default/beerchug.gif)
reharvey
post Jan 13 2011, 01:31 PM
QUOTE(ChrisNPDrider @ Jan 13 2011, 12:19 PM) *
I would like to hear from Andy or anyone that has tried this mod. Thanks, Ray
r_towle
post Jan 13 2011, 02:05 PM
Custom Member
Yes it works.
Keep the stroke the same, 71mm and put in the 103mm jugs.
Keep the camshaft the same...
You can change the heads to 46/38mm valves for a bit more flow.
You will need to tune the MPS.
It works.
Rich
reharvey
post Jan 13 2011, 02:13 PM
QUOTE(r_towle @ Jan 13 2011, 03:05 PM) *
Yes it works.
It works.
Rich
Thanks for the info Rich. I was sure someone has done this. Just wanted as much input as possible from other 914 owners before going ahead with this rebuild. Thanks, Ray
VaccaRabite
post Jan 13 2011, 02:17 PM
En Garde!
since you are increasing displacement by nearly 1/2 a liter, don't you need bigger injectors?
Zach
reharvey
post Jan 13 2011, 02:21 PM
QUOTE(Vacca Rabite @ Jan 13 2011, 03:17 PM) *
Zach
Will increasing the fuel pressure provide the extra gas that would be needed?
r_towle
post Jan 13 2011, 02:29 PM
Custom Member
You cant change the type of manifold pressure (short stroke and stock overlap) but you can change the volume.
You will need a way to tune your mps when you are ready.
Rich
reharvey
post Jan 13 2011, 02:47 PM
QUOTE(r_towle @ Jan 13 2011, 03:29 PM) *
Rich
I've tuned the MPS on several of my other cars so that's not a problem. Just hoping that the end result will give more go power without any major glitchs with the FI. Some people would just put on carbs but I've kept the FI on all of my 914s because it works so well.
johannes
post Jan 13 2011, 02:52 PM
Club Porsche 914 France member since 2005
Region Association: France
Then Jake Raby will come in and tell you 2056 is the limit ...
Welcome in the arena ...
The french guy ...
r_towle
post Jan 13 2011, 03:01 PM
Custom Member
QUOTE(reharvey @ Jan 13 2011, 03:47 PM) *
Rich
150-165 hp is the max D-jet really....and that would be with a 9.5:1 CR....
If you do that, its gonna get hot, so plan for the heat.
Manfold pressure is how drag racers use fuel injection, so there really is not an upper limit....but with our Djet you are dealing with fixed air/fuel maps that are hard coded.
You can use aftemarket FI and get alot better results, but you can also restrict the build to use Djet and that can be fun.
Same cam is the key. And that really sucks, but thems is the facts.
Same stroke is the key.
This leaves alot on the table for potential HP. but its still a fun car to drive
Get a header also...
Rich
reharvey
post Jan 13 2011, 03:21 PM
QUOTE(r_towle @ Jan 13 2011, 04:01 PM) *
Rich
Rich
Speaking of camshafts-------------------------I've used Web-Cam grind #73 on two of my fuel injected cars with good results and plan to use one on this motor. Hoping to keep the CR at 8.5:1. And yes----I've read that it'll run a little hot.
Brett W
post Jan 13 2011, 03:27 PM
Why would you handicap the motor? I realize it is a little more money, but in the grand scheme of things, a more modern FI unit will make the car that much more enjoyable.
Jake Raby
post Jan 13 2011, 05:51 PM
Engine Surgeon
There are really no limits in engine maniplation. The difference is what can SAFELY be done without losing the entire investment or creating an engine that does nothing well except idle. Been there..
Smart people won't try to build an efficient D jet engine above 2056cc, beyond that the compromises are great.
Projects that begin with compromise, end in demise.
Krieger
post Jan 13 2011, 07:54 PM
My engine is a 78 x 96 with a mild webcam for FI engines. It has been together and running extremely well for 10 years. I've been driving very hard at autocrosses for 8 years and it doesn't even leak a drop. And yes I built it! It does not run lean anywhere. No it does not make as much horsepower as Jakes, but it is a torqy SOB and it was probably less than 1/3 of the cost of his. I built this engine to pass smog and it did...barely. The compression is around 8.1:1 The fuel pressure is around 36 psi. Early 2.0 manifold pressure sensor/injectors (supposedly flow more gas and cheaper at the time). Stock rev limiter, larger or bored out throttle body. The big deal is to trick the brain into thinking its cold outside, so put a resistor inline with the head sensor. Mine took about 400 ohms resistance to accomplish this. I determined this with an O2 sensor in the exhaust and later it was checked on a chassis dyno. Do a search it has been discussed here before.
reharvey
post Jan 14 2011, 11:04 AM
QUOTE(Krieger @ Jan 13 2011, 08:54 PM) *
Thanks for the info Andy. Everyone has been very helpful. Think I'll go with the 96mm pistons and use the Web-Cam grind # 73 that I've use in my other engine rebuilds. Nice to hear from someone who has put one of these together himself. Ray
Chris Pincetich
post Jan 14 2011, 02:54 PM
B-)
Of course Andy built it himself! (IMG:style_emoticons/default/headbang.gif)
One day, I will build one too. Just waiting for the 1.7 to kick the bucket. If I get from the AX track to Sears Pt big track this year, that should speed things up (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 16th July 2025 - 03:57 AM
