> Will 2.4 L engine work with stock FI, Will stock FI work with a larger bore engine
reharvey
post Jan 13 2011, 10:25 AM
Post #21
I'm getting ready to build a 2.0 engine for my latest 914 project. I've put together several of these motors in the past but have always used the Euro type Mahle 94mm pistons. How big of a piston can I use and still retain the FI. I can make minor modification to the FI if need be. I've done this in the past. Has anyone out there try this?
reharvey   Will 2.4 L engine work with stock FI   Jan 13 2011, 10:25 AM
realred914   I'm getting ready to build a 2.0 engine for m...   Jan 13 2011, 10:28 AM
orange914   NOOOOOOOOOO   Jan 13 2011, 11:09 AM
orange914   oh :wttc: 2056 with MPS modification is about th...   Jan 13 2011, 11:11 AM
ChrisNPDrider   Maybe Andy will chime in. He has a very nice red 9...   Jan 13 2011, 11:19 AM
reharvey   Maybe Andy will chime in. He has a very nice red ...   Jan 13 2011, 01:31 PM
r_towle   Yes it works. Keep the stroke the same, 71mm and p...   Jan 13 2011, 02:05 PM
reharvey   Yes it works. Keep the stroke the same, 71mm and ...   Jan 13 2011, 02:13 PM
Vacca Rabite   since you are increasing displacement by nearly 1/...   Jan 13 2011, 02:17 PM
reharvey   since you are increasing displacement by nearly 1...   Jan 13 2011, 02:21 PM
r_towle   You cant change the type of manifold pressure (sho...   Jan 13 2011, 02:29 PM
reharvey   You cant change the type of manifold pressure (sh...   Jan 13 2011, 02:47 PM
r_towle   You cant change the type of manifold pressure (s...   Jan 13 2011, 03:01 PM
reharvey   [quote name='reharvey' post='1417425' date='Jan 1...   Jan 13 2011, 03:21 PM
johannes   Then Jake Raby will come in and tell you 2056 is t...   Jan 13 2011, 02:52 PM
Brett W   Why would you handicap the motor? I realize it is...   Jan 13 2011, 03:27 PM
Jake Raby   There are really no limits in engine maniplation. ...   Jan 13 2011, 05:51 PM
r_towle   There are really no limits in engine maniplation....   Jan 14 2011, 02:56 PM
realred914   There are really no limits in engine maniplation...   Jan 15 2011, 12:06 PM
Krieger   My engine is a 78 x 96 with a mild webcam for FI e...   Jan 13 2011, 07:54 PM
reharvey   My engine is a 78 x 96 with a mild webcam for FI ...   Jan 14 2011, 11:04 AM
ChrisNPDrider   Of course Andy built it himself! :headbang: ...   Jan 14 2011, 02:54 PM
Jake Raby   I'd be willing to bet that a 2.4 designed arou...   Jan 14 2011, 07:42 PM
Bleyseng   I'd be willing to bet that a 2.4 designed aro...   Jan 15 2011, 11:14 AM
Krieger   The biggest compromise for some is money!   Jan 14 2011, 08:03 PM
Jake Raby   The biggest compromise for some is money! W...   Jan 14 2011, 08:16 PM
Krieger   Hey Mr. Self Righteous, your way is not the only w...   Jan 14 2011, 10:32 PM
Valy   What about using the L-Jet? Is it better for big e...   Jan 15 2011, 01:40 AM
Jake Raby   Hey Mr. Self Righteous, your way is not the only ...   Jan 15 2011, 08:19 AM
76-914   Hey Mr. Self Righteous, your way is not the only...   Jan 15 2011, 10:09 AM
Bleyseng   Certain early longsnout MPS's have more range ...   Jan 16 2011, 04:43 AM
Bleyseng   Certain early longsnout MPS's have more range ...   Jan 16 2011, 04:44 AM
- Lo-Fi Version Time is now: 16th July 2025 - 05:31 PM
