FS: Zero Time 2056cc - SOLD, Professionally Built @ EMW/SCAT |
kconway |
Jan 19 2011, 09:21 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
SOLD, THANKS BILL! (IMG:style_emoticons/default/beer.gif)
Zero time 2056 motor assembled by European Motor Works/Scat 9/09 have receipt Balanced 96mm NPR pistons/cylinders Balanced crank, rods and flywheel New Stock T4 cam & followers Galley plugs replaced, case align bored Heads rebuilt, cracks welded up. Tons of NOS FI parts - NOS ECU (still in it's factory box) - NOS MPS (vacuum checked) - NOS TPS - Injectors (4 NOS, 4 rebuilt by Witchhunter) - Many more Powdercoated Tin and zinc plated parts Near new SSI HE's Triad exhaust New fuel hoses Fuel pump Alternator All new Bowlsby & OEM wire harnesses Many more items It presently sits as a long block as I haven’t had time to assemble it, decided to go with a six conversion. I had planned to keep it fuel injected so I kept the stock cam. $3800 As described + shipping $3200 without SSI and Triad +shipping Prefer not to ship, I'm in Long Beach, CA. Kev |
DanT |
Jan 19 2011, 09:27 PM
Kevin,
do you have pics of the various pieces and the long block? |
kconway |
Jan 19 2011, 09:32 PM
DanT |
Jan 19 2011, 09:35 PM
Is this motor built on a GA case?
Do you know what the compression ratio is supposed to be? |
kconway |
Jan 19 2011, 09:37 PM
DanT |
Jan 19 2011, 09:38 PM
thanks Kevin...
are you offering everything to complete the build into a running motor? |
kconway |
Jan 19 2011, 09:47 PM
thanks Kevin... are you offering everything to complete the build into a running motor? Yeah, well; everything listed plus I'm sure a few things I've left off. I think that gets you a complete running motor with a premium exhaust. Let me know if I left something out...I have alot of stuff and I'm sure somethings left off my list. All powdercoat, your old motor was my inspiration! Kev |
DanT |
Jan 19 2011, 09:49 PM
glad my old motor inspired someone (IMG:style_emoticons/default/biggrin.gif)
MikeM |
Jan 20 2011, 12:10 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi...could you please post some pics of the engine?
Cheers Mike |
kconway |
Jan 20 2011, 09:13 PM
Few more photos of misc stuff...
Balanced piston |
MikeM |
Jan 21 2011, 12:53 AM
Thanks for the pics...what happened to the other cylinder head?
Mike |
kconway |
Jan 21 2011, 08:37 AM
kconway |
Jan 23 2011, 09:46 AM
kconway |
Jan 25 2011, 08:01 AM
When assembled this is a complete motor. EVERYTHING as close to a factory new motor you will find even down to the wire harnesses! kev (IMG:style_emoticons/default/beerchug.gif) |
914 shifter |
Jan 25 2011, 06:33 PM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
(IMG:style_emoticons/default/icon_bump.gif) When assembled this is a complete motor. EVERYTHING as close to a factory new motor you will find even down to the wire harnesses! kev (IMG:style_emoticons/default/beerchug.gif) i have a 70 1.7 d jet. that looks like the perfect upgrade (IMG:style_emoticons/default/chowtime.gif) too bad i live in jersey (IMG:style_emoticons/default/hissyfit.gif) |
detoxcowboy |
Jan 25 2011, 10:25 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
(IMG:style_emoticons/default/icon_bump.gif) for the clean job, .. you can ship Engines to Jersey.. If you ever part that FI, I wantr to be first in line and to your house with cash.. local for the moment O.C.
kconway |
Jan 25 2011, 11:10 PM
kconway |
Jan 27 2011, 03:56 PM
kconway |
Jan 27 2011, 04:05 PM
Bill, you've got a email reply too.
Kev |
914 shifter |
Jan 28 2011, 06:20 PM
i have $100 bills with your name on them (IMG:style_emoticons/default/shades.gif) check e mail
Lo-Fi Version | Time is now: 14th May 2024 - 12:29 AM |
