Eric Taylor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 ![]() |
This car is an absolute blast. I have had this car for nearly 10 years, and I can’t believe I’m getting rid of it. Nothing cures bad day better than a top of drive towards the coast in this car. However, my life has changed a lot and I no longer can care for this car in the way that it deserves.
I have personally done a ton of work to this car in my ownership of it. The car replaced a previous 73 2.0 914 that met with a tree at the hands of a young drive nearly 10 years ago. That car provided an excellent amount of parts that one immediately sees in this car. The interior was swapped to this car as well as a number of small pieces. I selected what was best from both and put it into this car. The interior quality is surprisingly original and well preserved, something one must see to appreciate. Mechanically this car is in good condition. I replaced the clutch in it around 1000 miles ago and also had the clutch tube re-welded at that time. The transmission shifts well, including downshifting through all gears. I have also spent a great deal of money and time on the fuel injection system. I have replace the fuel injection harness, injectors, trigger points, TPS and MPS. At one point the car had an irradic fuel delivery issue. I replaced the listed parts to finally fix the issue. It also has had the cap, distributor, plugs, wires and compressor replaced recently. At that time I also had the car timed and the valves set. I have also replaced the voltage regulator within the last week. Structurally this car is very sound. This was the main reason that I originally purchased it. I will not call this a 100% rust free car; however, one would be very hard pressed to find one with as little rust as this car has. There is no rust in the long’s supporting the car, and the battery hole is structurally intact. The rear trunk has some surface rust in it; however, this area is structurally sound with no holes or thin areas. There are some other spots of surface rust in the car, but on the whole this car is rather rust free. A quick amount of research on this car will show that the areas listed are, more often than not, BIG problems with these cars. Please e-mail me with any questions. There is to much to list in the ad. Test drives are welcomed to seriously interested parties. I am not interested in shipping the car. Attached image(s) ![]() ![]() ![]() ![]() ![]() |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Hey guys I have looked this car over. I bought some wheels from Eric & gave it a good look. It does have some rust as he stated but not much. The rear trunk has the rust showed in the picture. There are no holes I could see there. Cleaned & treated I think would fix the trunk. There is a hole in the hell hole area. It isn't large & I think is just through the top layer. Longs are solid below as is the jackpoint. A small patch & treating the area would take care of this. I have seen plenty of hell holes. This car is structerally solid there. It is not perfect obviously but is very solid daily driver. There is also some bubbling above the drivers door indentation on the rear quarter. Just below the targa vinyl.
I'd be happy to talk to anyone about it if they have questions. Eric is a stand up guy & will answer any question honestly though. It is only 10 minutes from my work if you want anything more specific. I am more than willing to go back by to check on anything. Hate to lose you Eric but best of luck with the sale (IMG:style_emoticons/default/biggrin.gif) . This really is a nice solid 914 (IMG:style_emoticons/default/driving.gif) |
Eric Taylor |
Bump to offers.
Eric Taylor |
Bump to a reduced price
Eric Taylor |
Bumptiy bump
Lo-Fi Version | Time is now: 27th September 2025 - 02:21 AM |
