How to ID which distributor is installed? |
NJ914Guy |
Feb 3 2011, 04:59 PM
Member Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
Per my maintenance records from the PO, I seem to have a 009 distributor, installed to accommodate the conversion from FI to carb. Where should I look to ID the make/model numbers?
jt914-6 |
Feb 3 2011, 05:08 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
You might be able to see the numbers with a mirror....if not, pull the dist. out and find the number on the body of the dist......
underthetire |
Feb 3 2011, 05:23 PM
And if no vacuum can, probably a 009.
Lo-Fi Version | Time is now: 5th June 2024 - 05:54 AM |
