rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
I had a few leftover shift knobs lying around so I built a coat rack too.
rnellums |
some new re-upholstry:
rnellums |
And the seat in the car:
![]() Now I'm into wheel refinishing! Before: ![]() After: ![]() And now, Thank God, I'm all caught up. New posts to come as work progresses. New trunk mount and 140 # springs are on the list, as well as perhaps pblasted and painted trailing arms! -Ross |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Nice work! You rock! Time to make that Olympic blue a driver! (IMG:style_emoticons/default/idea.gif)
rnellums |
unfortunately, this is what happened to the olympic blue car...
MDG |
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None ![]() |
Nice! (IMG:style_emoticons/default/thumb3d.gif) I Love black 914s
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
Nice thread and great pictures.
Great idea with the horn. It is fun when you can keep tweaking while being able to drive your car. John |
914 shifter |
airhead ![]() ![]() Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States ![]() |
nice work.
rnellums |
roadster fan |
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California ![]() |
Nice Car! thanks for posting the pics. Keep driving while you improve it, my 73 has been on jackstands for years.....
Jim |
rnellums |
Nice Car! thanks for posting the pics. Keep driving while you improve it, my 73 has been on jackstands for years..... Jim Mine was on jackstands for the first four years of it's time with me. My goal is not to have it out of commission for mOre than a month for the next three years. Next project: elephant racing bushings for the rear. |
bembry |
Senior Member ![]() ![]() ![]() Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region ![]() |
Great work--you've done terrific things with that 914.
rnellums |
I finished re-finishing the spare and am really happy with the results, it just took forever. steady as she goes I guess.
Before: ![]() After: ![]() Centers: ![]() |
rnellums |
wow... not the right order. Some more pictures though
rnellums |
I am also getting ready to re-work the rear suspension. Here are some prep shots
![]() ![]() Also on the to-do list is welding in a new trunk hinge mount: ![]() |
hwgunner |
914 Parts @ Discount Prices 800.321.5432 ![]() ![]() ![]() Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None ![]() |
rnellums |
I just finished pulling the engine so I can weld in that new trunk mount and swap the clutch. The pull went well, but much to my dismay I discovered to messy PO repairs I had thought I avoided until tonight. The Passenger trailing arm, as well as some of the sheet metal in the hell hole seems to have been replaced. I also found some evidence of a separate fender being welded on in parts. To add insult to injust I also found a hairline crack in the paint at the edge of the door. upon closer inspection I found that there was a layer of bondo underneath. I went and did the magnet test and found that even my strongest magnet could barely hold. I knew it had damage ther, but had hoped the paint shop did a good job of pulling it out. Ok. Rant over. Back to work!
rnellums |
Here are some more pictures of the the engine and transmission apart, along with a shot of the clutch that came out as compared to the brand new clutch.
Some of the clutch dragging I had before I pulled out the tranny I think I can attribute to the absence of shims on the throwout arm pivot ball. The clutch seemed to be in prety good shape. ![]() ![]() Attached image(s) ![]() |
rnellums |
I removed the rockers to get better access to the trailing arms. As I did I noticed something strange on the longs. Ten minutes later after pulling what felt like 2 pounds of caulk off the car I ended up with this. a 10" crack up the long. Nothing serious by 914World standards, but caulk? really?
![]() So I pulled out my trusty MIG and welded up the cracks. Not a permanent solution, but it sould buy me some time before I can dig into it for real. I would really appreciate it if those with more knowledge could chime in on the strength of such repairs. I also am getting hookied up with a weld on clamshell long from a friend here that should allow me to strengthen it further. ![]() The welds dont look half bad after some grinding! ![]() |
rnellums |
To cheer myself up I went over to senor O'sheas to grab some goodies. Check out this haul!!!
![]() I also Spent some time today grounding down the old trunk mount in preparation for the replacement. ![]() |
Lo-Fi Version | Time is now: 4th July 2025 - 05:07 AM |
