WTB - side shifter rod (rear portion) **FOUND** |
moparrob |
Feb 10 2011, 09:16 AM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
**FOUND** I just realized the rear-most portion of my shift rod is pretty badly pitted, so I want to replace it. Looking for a side shifter model. I actually only need the rear-most 8 inches since I'll be modifying the rod, so if you have a tweaked one with a good end section I could use that. email works best: robrose426@att.net Thanks |
sawtooth |
Feb 10 2011, 09:25 AM
Member Group: Members Posts: 297 Joined: 25-June 08 From: Boise, ID Member No.: 9,211 Region Association: Intermountain Region |
I just realized the rear-most portion of my shift rod is pretty badly pitted, so I want to replace it. Looking for a side shifter model. I actually only need the rear-most 8 inches since I'll be modifying the rod, so if you have a tweaked one with a good end section I could use that. email works best: robrose426@att.net Thanks I've got one for sale that is in good condition. I'll send an email. |
bdstone914 |
Feb 10 2011, 11:19 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
email sent
Bruce |
moparrob |
Feb 10 2011, 11:19 PM
Thanks for the prompt response guys. With Dean's help I have located the rod I need. One step closer to getting off the jack stands...
Lo-Fi Version | Time is now: 13th May 2024 - 09:34 PM |
