5 Bolt Hubs, Need rear rotor advice please |
ber914 |
Apr 29 2004, 02:07 AM
Newbie Group: Members Posts: 43 Joined: 8-April 04 From: Sydney, Australia Member No.: 1,908 |
My car has 5 bolt rear hubs with standard 914 calipers. Can I use 914-6 rear rotors
with these calipers or do I have to use 914 rotors and redrill them? Robert |
davep |
Apr 29 2004, 05:17 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I don't think you will have any issues with the 914/6 rotors. I never did. Some say the rotor is too great a diameter, so they turn the rotor down, or clearance the caliper.
ArtechnikA |
Apr 29 2004, 05:18 AM
there -may- be a slight clearance issue.
i don't recommend grinding clearance on a caliper, and i believe the preferred solution is to have a little bit of the rim of the disk trimmed off (lathe stuff). of course, the real solution is 914.6 calipers, but that may change your brake balance (bias) a bit too. |
JFJ914 |
Apr 29 2004, 07:11 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
I didn't have any fitment issues with the 914-6 disk and the stock -4 caliper when I put them on my 5 lug conversion.
seanery |
Apr 29 2004, 07:13 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm hoping for no issues, since I'm doing the same.
Bleyseng |
Apr 29 2004, 07:18 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I clearanced the inside of the 914 4 caliper, mostly cleaning up the poor casting.
Geoff |
Lo-Fi Version | Time is now: 10th June 2024 - 04:35 AM |
