MPS Question, 1.7L vs. 2.0L |
rwilner |
Feb 25 2011, 06:29 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
While doing some work on the car last night, I noticed my MPS # was 0 280 100 049 (022 906 051E). I have a 73 2.0L, and according to PBanders site, the correct MPS # is 0 280 100 037 (022 906 051C).
Anyone know how the 049 part will effect the running of my engine vs. the correct 037 part? Thanks Rich |
sfrenck |
Feb 25 2011, 06:41 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
While doing some work on the car last night, I noticed my MPS # was 0 280 100 049 (022 906 051E). I have a 73 2.0L, and according to PBanders site, the correct MPS # is 0 280 100 037 (022 906 051C). Anyone know how the 049 part will effect the running of my engine vs. the correct 037 part? Thanks Rich Better take inventory of all your FI parts, esp. the CHT and the ECU, and make sure that everything "matches" per the pbanders information. That MPS won't work on your car (unless it's been opened up and adjusted by someone who knows what they are doing - and even then I'm not sure). In my opinion - your CHT is the smoking gun. If it is the 0 280 130 017 (and it works correctly), you should go ahead and get yourself an 037 MPS. Mine was toast (resistance readings taken with an ohm meter were out of spec) - and it seemed like it was an impossible part to find. Ended up going with the pbanders suggestion of changing to a '74 2.0L setup. |
rwilner |
Feb 25 2011, 06:54 AM
Better take inventory of all your FI parts, esp. the CHT and the ECU, and make sure that everything "matches" per the pbanders information. That MPS won't work on your car (unless it's been opened up and adjusted by someone who knows what they are doing - and even then I'm not sure). In my opinion - your CHT is the smoking gun. If it is the 0 280 130 017 (and it works correctly), you should go ahead and get yourself an 037 MPS. Mine was toast (resistance readings taken with an ohm meter were out of spec) - and it seemed like it was an impossible part to find. Ended up going with the pbanders suggestion of changing to a '74 2.0L setup. Scott, Thanks for the quick feedback, I'll pull the CHT and check it tonight. It is very unlikely the MPS installed on my car has been adjusted. Just to be clear: when you say you went to a 74 setup, that means you have:
Anything else I'd need to swap out? |
sfrenck |
Feb 25 2011, 07:36 AM
That's the setup I went to... nothing else needs to be changed. Be careful with your CHT when you pull it!! I've read nasty stories on this site with people stripping threads, breaking the head of the CHT off and not being able to get the rest out of the engine, etc. Use a deep socket so that you can coil up the wire from the CHT inside of it. Check the resistance readings on the CHT vs. what pbanders site says for the CHT in ice water, room temp, and boiling water to make sure the piece is working correctly. I suppose you could check the room temp value and the warmed up engine value with the CHT in the car (I can also check the ice bath value in my unheated garage). Oh yeah, check your distributor number too. You'll want the 039 905 205 or 205A. |
dr914@autoatlanta.com |
Feb 25 2011, 09:13 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end
While doing some work on the car last night, I noticed my MPS # was 0 280 100 049 (022 906 051E). I have a 73 2.0L, and according to PBanders site, the correct MPS # is 0 280 100 037 (022 906 051C). Anyone know how the 049 part will effect the running of my engine vs. the correct 037 part? Thanks Rich |
rwilner |
Feb 25 2011, 09:21 AM
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end George Seems like the 043 is more available than the 037 (a unicorn). Would you recommend the 043 over the 049 for a 73 2.0L application? |
sfrenck |
Feb 25 2011, 09:42 AM
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end George Seems like the 043 is more available than the 037 (a unicorn). Would you recommend the 043 over the 049 for a 73 2.0L application? You can get rebuilt MPS's from Fuel Injection Corp via PartsHeaven. Cost is <$200 after core trade in (for the 037 or 043). The unicorn is the 017 CHT. |
Feb 25 2011, 09:57 AM
I would install the 037 in my personal car yes. One can certainly notice the difference in top end (high rpm) power FI rebuilds them but these days with the inferior quality of the diaphragms, they actually do not work as well as the originals. If you can find a good original one (037) you would be better off. We of course sell the FI 049, 043, and 037.
rmital |
Feb 25 2011, 11:39 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end George Seems like the 043 is more available than the 037 (a unicorn). Would you recommend the 043 over the 049 for a 73 2.0L application? ...I guess to answer your questions....043 |
rwilner |
Feb 25 2011, 11:52 AM
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end George Seems like the 043 is more available than the 037 (a unicorn). Would you recommend the 043 over the 049 for a 73 2.0L application? ...I guess to answer your questions....043 Thanks Ray. I'll keep an eye out for one. |
sfrenck |
Feb 25 2011, 12:00 PM
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end George Seems like the 043 is more available than the 037 (a unicorn). Would you recommend the 043 over the 049 for a 73 2.0L application? ...I guess to answer your questions....043 I don't know - I still think the answer is get the 037 MPS if you have the working 017 CHT. |
rmital |
Feb 25 2011, 01:03 PM
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end George Seems like the 043 is more available than the 037 (a unicorn). Would you recommend the 043 over the 049 for a 73 2.0L application? ...I guess to answer your questions....043 I don't know - I still think the answer is get the 037 MPS if you have the working 017 CHT. I didn't think my reading comprehension was that great....but....I think rich is asking if it was "between" him using a 043 or a 049, which one would be better! ....the answer would be "043" reading deeper, seems finding a 037 would be great, not that easy for the right price? an 043 is more common and could be found for the right price.... he has an 049....so....should he keep running the 049, or pick up a 043? |
AndyB |
Feb 25 2011, 01:05 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
I was trying to help Rich out but my 037 doesnt hold pressure (IMG:style_emoticons/default/dry.gif)
sfrenck |
Feb 25 2011, 01:20 PM
The 049 is actually for a 1.7 but will work fine for the 2.0 the main difference is the enrichment for the increased displacement. The only downside is that you may not have the acceleration of the 2.0 pressure sensor the 043. The 037 so called "european" pressure sensor will provide increased power at the top end George Seems like the 043 is more available than the 037 (a unicorn). Would you recommend the 043 over the 049 for a 73 2.0L application? ...I guess to answer your questions....043 I don't know - I still think the answer is get the 037 MPS if you have the working 017 CHT. I didn't think my reading comprehension was that great....but....I think rich is asking if it was "between" him using a 043 or a 049, which one would be better! ....the answer would be "043" reading deeper, seems finding a 037 would be great, not that easy for the right price? an 043 is more common and could be found for the right price.... he has an 049....so....should he keep running the 049, or pick up a 043? I recommended that he go with the 043 back in Posts #2 and #4. Guess it boils down to if you trust how FIC rebuilds and calibrates MPS's, though. I figured that I'd rather go with a rebuilt unit and the 18 month warranty than get an original one with unknown life expectancy. |
AndyB |
Feb 25 2011, 01:26 PM
rmital |
Feb 25 2011, 01:46 PM
can't we go to Radio Shack and make a bunch of those..... (IMG:style_emoticons/default/biggrin.gif) |
rwilner |
Feb 25 2011, 02:00 PM
Andy Did you measure resistance from the electrical connection to ground? If the thermistor is still good, I can salvage that unit by rebuilding the pigtail. Radioshack < digikey! |
SLITS |
Feb 25 2011, 02:04 PM
Hey Ray ... just pick up a rheostat and wire it in. You can fine tune while driving.
Of course PG will roll over and swear that it's not OE and therefore makes the car worthless. I believe that resistor is 270 ohms, but again, you can't replace it with a current 270 ohm resistor as it is not OE. |
rwilner |
Feb 25 2011, 02:45 PM
I recommended that he go with the 043 back in Posts #2 and #4. Guess it boils down to if you trust how FIC rebuilds and calibrates MPS's, though. I figured that I'd rather go with a rebuilt unit and the 18 month warranty than get an original one with unknown life expectancy. Over $400 not including core charge!! At that point I'm well on my way to an SDS system... |
shulew 3 |
Feb 25 2011, 02:48 PM
desert toy Group: Members Posts: 30 Joined: 2-July 10 From: Palm Springs, CA Member No.: 11,902 Region Association: Southern California |
Hey Ray ... just pick up a rheostat and wire it in. You can fine tune while driving. Of course PG will roll over and swear that it's not OE and therefore makes the car worthless. I believe that resistor is 270 ohms, but again, you can't replace it with a current 270 ohm resistor as it is not OE. I just bought a pack of 270 ohm resistors at Radio Shack for .99 cents plus tax...soldered one in the line from CHT to ECU...Makes the car run like new!! Have the 037 MPS....they are about the size of a kernel of rice! with a wire lead on each end.....shrink cover it and your good to go! lew |
Lo-Fi Version | Time is now: 20th May 2024 - 08:08 PM |
