Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
Barrel Connector for the Accelerator Cable-Original Style with Slot screw
PET 702-00 Pos. 18 & 19 Qty. 1 This is the one with flats on the side for a wrench to hold the barrel while you're tightening/loosing the screw. Barrel is yellow plated and screw is clear zinc plated. ![]() |
A&PGirl |
If you want to match the PET exactly, you can remove the screw and replace it with a Hex head bolt M5x10.
The new style barrel connector that many use is completely round and comes with either a slot screw or hex head bolt. The round style makes it very difficult to hold with tightening or loosing the screw/bolt. |
Lo-Fi Version | Time is now: 11th July 2025 - 02:08 AM |
