questions |
questions |
pauldunn |
Feb 27 2011, 11:21 PM
dudeface Group: Members Posts: 41 Joined: 9-February 11 From: Arizona Member No.: 12,687 Region Association: Southwest Region |
As you can tell by my title "newbie", i and new to the world of 914s. I know this model was made from 70-76, and there are a few differant sized engine that were used. my car that i just aquired looks like it has been sitting for quite a while, and all the labels and stickers are long gone. There are quite a few problems to be worked out. Question 1, How do i know what size engine is in my car, assuming it is still stock which i think it is. Question 2 - with battery cables hooked to battery, the 2 red arched light in the fuel level guage blink just like the blinker would weather key is in on position or not. Brake reservoir is bone dry. would that cause the blinking? Ive read on here that there is a "reset" button on the master cylinder? is it an obvious button or will i have to look for it? THanks for the help.
Are these cars carburated or fuel injected? mine looks like it is carburated, but some listings i just found make me worried. If i read my schematic right the computer for the fuel injection plugs into the relay block in the engine compartment, am i correct? If they are fuel injected, and that is where the computer plugs into, i am screwed cause i cant find the computer and that plug is empty. where would the computer be? - Paul |
VaccaRabite |
Feb 28 2011, 10:12 AM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
The blinking red light is the brake failure warning light. Yes, its due to the res being dry. Fill it with Dot3 and start bleeding the brakes using either a pressure bleeder or the "long tubes" method. LOTS of threads about both here on the site. The reset button will only work once the brakes are full of fluid and the air is bled out.
Engine can be determined a few different ways. What year is your car? it should still have vin tags. Please consider entering your VIN info here: http://www.914world.com/specs/chasnrs.php Does the engine have carbs, or the fuel injection still on it? Posting a pic of the engine would lead many here to be able to tell what the engine is. Zach |
luskesq |
Feb 28 2011, 02:09 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
As you can tell by my title "newbie", i and new to the world of 914s. I know this model was made from 70-76, and there are a few differant sized engine that were used. my car that i just aquired looks like it has been sitting for quite a while, and all the labels and stickers are long gone. There are quite a few problems to be worked out. Question 1, How do i know what size engine is in my car, assuming it is still stock which i think it is. Question 2 - with battery cables hooked to battery, the 2 red arched light in the fuel level guage blink just like the blinker would weather key is in on position or not. Brake reservoir is bone dry. would that cause the blinking? Ive read on here that there is a "reset" button on the master cylinder? is it an obvious button or will i have to look for it? THanks for the help. Are these cars carburated or fuel injected? mine looks like it is carburated, but some listings i just found make me worried. If i read my schematic right the computer for the fuel injection plugs into the relay block in the engine compartment, am i correct? If they are fuel injected, and that is where the computer plugs into, i am screwed cause i cant find the computer and that plug is empty. where would the computer be? - Paul Assuming you have a four cylinder it came stock fuel injected. The computer would be mounted on the firewall in front of the battery. ECU's are available from a number of sources. If you don't know the year of your car it should be on the tag found on rear of driver's door opening. |
livinglobotomy |
Feb 28 2011, 02:29 PM
Newbie Group: Members Posts: 19 Joined: 19-January 11 From: maui Member No.: 12,612 Region Association: None |
before you do anything.... take the parking brake off. your flashing will disappear as this is the parking brake warning signal and is working as designed.
McMark |
Feb 28 2011, 02:35 PM
QUOTE The blinking red light is the brake failure warning light Or, the parking brake warning light. It's both. (IMG:style_emoticons/default/wink.gif) For the best information for you and fun for us, post some pictures of the car, trunks, interior, engine bay and we can tell you all sorts of things that we see. (IMG:style_emoticons/default/biggrin.gif) |
Feb 28 2011, 05:46 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Some info on different bits about the 914. Both are a bit outdated now, but much of the info is still quite solid.
FAQ: http://www.pelicanparts.com/techarticles/9...Darling_FAQ.htm Buyer's Guide: http://www.pelicanparts.com/914/How_to_buy_a_914.htm No US-bound four-cylinder 914 ran carbs originally. Only the Sixes and the European-spec 1.8s did. The blinking lights may be due to the brake warning system (either a loss of pressure or the handbrake being up will trigger it), but both should only come on when the key is on. You may have an ignition switch problem, or something shorting an "always hot" wire to a "switched power" wire. --DD |
bandjoey |
Feb 28 2011, 06:10 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Post your location. I'll be there's someone close by that can help. Also, when you get more info on the motor - year - etc. post that for additional help. Simple cars to work on. Best education is to start back about 20 pages and read all of the tech posts here and use the search button. |
euro911 |
Feb 28 2011, 06:27 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Since the car has been sitting for some time, check the braking system thouroughly before driving it. The master cylinder and/or calipers and/or any of the hoses could be leaking (hence the empty reservoir).
The PO may have removed the ECU (computer), which you won't need when runing with carbs. (IMG:style_emoticons/default/agree.gif) Pix of everything would help to identify what you have for a drive train. |
pauldunn |
Feb 28 2011, 08:13 PM
silver74insocal |
Feb 28 2011, 08:17 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
engine bay please (IMG:style_emoticons/default/popcorn[1].gif) and (IMG:style_emoticons/default/welcome.png) welcome to the madness
pauldunn |
Feb 28 2011, 08:22 PM
pauldunn |
Feb 28 2011, 08:23 PM
pauldunn |
Feb 28 2011, 08:24 PM
pauldunn |
Feb 28 2011, 08:25 PM
pauldunn |
Feb 28 2011, 08:26 PM
silver74insocal |
Feb 28 2011, 08:29 PM
yep somebody put a carb on there for you so dont worry about the ecu. on your last picture showing the green carb return spring, just underneath where it is attached in the back you should see your engine code# stamped on the engine case. if you post the first 2 letters of the # we can tell you what engine you have, or record it and find it in the links previously provided (IMG:style_emoticons/default/popcorn[1].gif)
Lennies914 |
Feb 28 2011, 08:35 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I'm sure more will chime in but, it's a carburated 1.7 or 1.8. I see an a/c compressor also.
pauldunn |
Feb 28 2011, 08:42 PM
yes that it is. doubt it has any refridgerant in it though. cant get the engine running enough to tell. and as far as the engine code, where is it? i looked all over that engine bay and cant find anything. will it say in the vin?
majkos |
Feb 28 2011, 08:49 PM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
if the bumpers are original
the motor a 1.7 with AC Good god man I would drop the motor and give a good cleaning first Get rid of the ac, pretty well assuming the refrig. is gone You have the"Progressive carb" set-up on once was Fuel Injection |
silver74insocal |
Feb 28 2011, 09:35 PM
and as far as the engine code, where is it? i looked all over that engine bay and cant find anything. will it say in the vin? see my last post. what is that original color? you can see it in the front trunk pic and in the engine bay pic. it looks yellow...but kinda not (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 20th April 2024 - 01:13 AM |
