WTF: Oil Leak, Pulling the motor... |
415PB |
Apr 30 2004, 06:04 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Have to pull the motor this weekend. I have an annoying oil leak from the base of the #1 cylinder. I rebuilt the engine last year and have about 600 miles on it. I used the damn sealing rings after lapping the cylinders to the case. I just figured I would use them and didn't think I would have a problem with oil leaks.
So, I plan on pulling each cylinder, lap them to the case again and then delete the sealing ring (like I should have done the first time). I have some Curil T (sealant) and was wondering if I could use this to seal the cylinder to the case. Has anyone done this before or is just lapping the cylinders to the case good enough? Thanks for the help. |
Aaron Cox |
Apr 30 2004, 06:33 PM
i believe i used Permatex 3H aviation sealant.
Mark Henry |
Apr 30 2004, 06:48 PM
Lapping to the case is not required.
Clean everything spotless, degrease it with some brake cleaner, then run a bead of hi-temp RTV silicone around the base of the jugs. (the part that the ring sits into.) Put on the clean ring and do the silicone again, then replace the jugs. Not a lot of silicone, just a bead then wipe it with your finger, much like caulking a bathtub. You are confusing lapping the heads to the jugs and deleting the head sealing ring. |
tracks914 |
Apr 30 2004, 07:19 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
When I took my engine apart it didn't have sealant on the cylinder base rings. (and no leaks either) When I put it back together I didn't use sealant there. Should I have or is it just a precaution? (IMG:style_emoticons/default/confused24.gif)
swood |
Apr 30 2004, 07:41 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
What about some sort of sealant between the jugs and heads? Can this help/hurt?
Joe Ricard |
Apr 30 2004, 07:51 PM
Nope good solid metal to metal contact at the head to cylinder joint. After lapping of course. Don't know of any sealant that could stand up to the combustion chamber violence. (high pressure fire proof).
415PB |
Apr 30 2004, 08:54 PM
QUOTE(Mark Henry @ Apr 30 2004, 04:48 PM) Lapping to the case is not required. Clean everything spotless, degrease it with some brake cleaner, then run a bead of hi-temp RTV silicone around the base of the jugs. (the part that the ring sits into.) Put on the clean ring and do the silicone again, then replace the jugs. Not a lot of silicone, just a bead then wipe it with your finger, much like caulking a bathtub. You are confusing lapping the heads to the jugs and deleting the head sealing ring. Yep, I was definately confused...Thanks Mark. So I should leave the sealing rings, but use a good sealant. Is this correct? or should I delete the sealing rings like that one bulletin says and just use a good sealant? |
Aaron Cox |
Apr 30 2004, 09:21 PM
*leave the rings in where the jugs meet the case, and use a good sealant.
*at the head, lap the jug to the head and delete the sealing ring like the bulletin says. clear as glass now my friend (IMG:style_emoticons/default/biggrin.gif) |
415PB |
Apr 30 2004, 10:27 PM
Thanks Aaron.........
Levi |
May 1 2004, 12:06 AM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
Rod, If I lived anywhere close to ya I'd come give ya a hand just to see how its done, I've done many small block chevys but these air cooled engines are new to me....have fun.... (IMG:style_emoticons/default/beerchug.gif)
415PB |
May 1 2004, 12:11 AM
QUOTE(Levi @ Apr 30 2004, 10:06 PM) Rod, If I lived anywhere close to ya I'd come give ya a hand just to see how its done, I've done many small block chevys but these air cooled engines are new to me....have fun.... (IMG:style_emoticons/default/beerchug.gif) I'd gladly fly you out here to help (IMG:style_emoticons/default/biggrin.gif) I'm dreading it, but I am sure it will go smoothly. |
Levi |
May 1 2004, 12:18 AM
Hell I got a better idea, drive it up here I'll make some room in the shop for it, then when we finish your car we can tear into my 2.0 (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif)
Well it sounds good to me (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Levi |
May 4 2004, 06:31 PM
Well Rod did you pull your engine and fix the leak??
415PB |
May 4 2004, 09:03 PM
Levi, didn't get a chance to do it. I ended up powdercoating 22 pieces of tin for a 63 VW Bus and the next day I ended up powdercoating 12 pieces for a 72 super beetle conv. Made lots of money though. I need the extra income for my project, so it actually worked out pretty good. More than likely I will do it this weekend, I'll give you a call and let you know how it went. Oh, and please let me know when Chad receives his package.
Levi |
May 4 2004, 11:18 PM
Sounds like a plan. I'll look for your call...
I'll E-mail you... Later (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:54 AM |
