FI Injector rack - trying to put all new parts together, What lube is recommended for the elbows-to-rail & elbows-to-inecto |
Pat Garvey |
Mar 6 2011, 06:06 PM
I've tried spit & it doesn't work!
Pat |
Bleyseng |
Mar 7 2011, 04:20 AM
elbow grease!
just push harder and twist. |
tod914 |
Mar 7 2011, 08:55 AM
Use gasoline on it. It will slide on much easier. One of the guys suggested that when I was redoing my fuel lines.
underthetire |
Mar 7 2011, 09:43 AM
KY has many uses. (IMG:style_emoticons/default/sheeplove.gif)
zymurgist |
Mar 7 2011, 10:21 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I use dish soap if I can't fit it when dry.
Pat Garvey |
Mar 7 2011, 04:41 PM
Thanks! Don't have KY, but have a couple of substitutes to try. Will attempt penetration with a warming lube. Will let you know how it comes out (IMG:style_emoticons/default/av-943.gif) . Sounds like more fun than elbow grease! Pat |
Pat Garvey |
Mar 8 2011, 04:54 PM
Got 'em on! Astroglide!
Now I need to work on the injectors - 'nother thread. Yes, I know the date is incorrect! Attached thumbnail(s) |
914_teener |
Mar 12 2011, 05:44 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Pat Garvey |
Mar 13 2011, 03:46 PM
Got 'em on! Astroglide! Now I need to work on the injectors - 'nother thread. Yes, I know the date is incorrect! Pat, Where'd you get the elbows? Got them off of eBay. Fellow had 4 used injectors & clips, plus 20 fi clamps, new top & bottom injector seals and new elbows. Didn't really want anything but the elbows, but I got the lot for 24 bucks. Everything after the elbows was gravy. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:58 PM |
