Bodyguys, Where do you get your sandpaper?, What do you use? |
sean_v8_914 |
Mar 9 2011, 09:31 AM
bbrock |
Sep 14 2018, 11:21 AM
Thought I'd bump this to see if anyone has anything new to add. I'm getting ready to buy sandpaper supplies. I've been using a roll of Norton 80grit purchased at my local paint supply for blocking bare metal for dent straightening. Great stuff, but at almost $50/roll, I thought I'd explore some other options before buying the assortment of grits I'll need to sand primer before basecoat. |
TheCabinetmaker |
Sep 14 2018, 11:30 AM
Mirka gold.
burton73 |
Sep 14 2018, 01:10 PM
burton73 Group: Members Posts: 3,484 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Andyrew |
Sep 14 2018, 02:16 PM
7 years later I still use these guys... |
bbrock |
Sep 14 2018, 02:27 PM
7 years later I still use these guys... Hi Andrew, It was actually a visit to the tcpglobal that led to me bumping your old thread. The only PSA rolls I found on their site was Duragold which is half the price of other brands, but haven't found much info (good or bad) about its quality. Any experience with it? |
76-914 |
Sep 14 2018, 03:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,483 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Andyrew |
Sep 14 2018, 03:33 PM
7 years later I still use these guys... Hi Andrew, It was actually a visit to the tcpglobal that led to me bumping your old thread. The only PSA rolls I found on their site was Duragold which is half the price of other brands, but haven't found much info (good or bad) about its quality. Any experience with it? These reviews should help you (IMG:style_emoticons/default/smile.gif) https://www.amazon.com/Dura-Gold-Premium-Co...customerReviews I havent used the products myself but have heard great things. I ended up using the local 3M products on my projects and never ran out, but as mentioned I have heard great things about it. |
mb911 |
Sep 14 2018, 03:54 PM
914 Guru Group: Members Posts: 6,800 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Mirka and 3m is what I use.. Local paint supply store.
live free & drive |
Sep 14 2018, 04:10 PM
Member Group: Members Posts: 154 Joined: 29-June 16 From: New Hampshire Member No.: 20,159 Region Association: None |
atuobodytoolmart.com has been consistently the cheapest place to buy 3M that I have found -free shipping over $99 too -no affiliation, satisfied customer
For example: https://www.autobodytoolmart.com/3m-wetordr...ve-p-11239.aspx |
914pipe |
Sep 14 2018, 04:11 PM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
3M, Norton and Indasa (the one with the Rhino logo)
914forme |
Sep 14 2018, 04:56 PM
Any body use the new 3M ceramic grit. It is about 2x the price of standard stuff, reviews say it last for ever. Just not sure if these reviews are on the payroll so to speak. (IMG:style_emoticons/default/confused24.gif)
Andyrew |
Sep 14 2018, 05:10 PM
Any body use the new 3M ceramic grit. It is about 2x the price of standard stuff, reviews say it last for ever. Just not sure if these reviews are on the payroll so to speak. (IMG:style_emoticons/default/confused24.gif) I find sandpaper gums up much quicker than it wears. I would typically keep a wire brush next to me and once the paper was mostly loaded I would brush it real quick.. But there would be stuck gummy spots that wouldnt come off, after a while the paper is not reliably flat. This is when I would replace it. I typically have a separate sandpaper board specifically for knocking initial filler or primer down as thats the stickiest. With how good current sandpaper is, I dont think its worth the cost for anyone other than a pro shop. |
worn |
Sep 14 2018, 06:24 PM
can't remember Group: Members Posts: 3,143 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Any body use the new 3M ceramic grit. It is about 2x the price of standard stuff, reviews say it last for ever. Just not sure if these reviews are on the payroll so to speak. (IMG:style_emoticons/default/confused24.gif) I find sandpaper gums up much quicker than it wears. I would typically keep a wire brush next to me and once the paper was mostly loaded I would brush it real quick.. But there would be stuck gummy spots that wouldnt come off, after a while the paper is not reliably flat. This is when I would replace it. I typically have a separate sandpaper board specifically for knocking initial filler or primer down as thats the stickiest. With how good current sandpaper is, I dont think its worth the cost for anyone other than a pro shop. I can clog it just fine. But sand paper can lose the cutting edge real fast sometimes. In my experience you can feel the edge. My spare time is free, but using worn out paper gets me impatient. |
porschetub |
Sep 15 2018, 02:33 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Just completed a full repaint on a Golf,used Norton no fil for prep not only cause I had a lot left over from previous work but find it really good,ditto for their fine wet and dry,I don't believe there is a good cheap paper tried most..rubbish really.
I don't know what you guys pay in the US but here quality paper is around $1 a sheet ,can be less if you shop around. We generally bemoan the cost of paint but consumables like sandpaper,tape and plastic masking really pumps the cost up further,this is not a cheap exercise even when you go DIY. |
Lo-Fi Version | Time is now: 19th April 2024 - 04:03 AM |
