Razorbobsr |
Member ![]() ![]() Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest ![]() |
As you guys said, cleaned jets in carb, replaced plugs and wires, smooth at 900 rpms in drive, smooth at 2/3/4 K rpms in driveway, pulls hard W/O, sill I have a miss-fire that I can feel coming and going[surging, sound of engine when all 4 hit at proper times] Could I have a coil prob? Or where off to next?? 2L/carbs/5K sense rebuild/1500 miles driven to get this car home..... NKG plugs but do have Bosh plugs waiting...... Getting warmer outside, Help! Bob PS, British car friends are starting to make fun of the 914........... AND ME
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,755 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Where in the rpm range is it missing? Is it missing when you are doing low load cruising? Or when you have your foot in and real power going down? Could be that your mIn jets are a tad big.
Razorbobsr |
Where in the rpm range is it missing? Is it missing when you are doing low load cruising? Or when you have your foot in and real power going down? Could be that your mIn jets are a tad big. |
VaccaRabite |
Can you get it to miss sitting in your driveway? Without load maybe not. But if you can, you can isolate the bad cylinder with a timing light (find out which cylinder is not firing consistantly.)
Zach |
Razorbobsr |
Can you get it to miss sitting in your driveway? Without load maybe not. But if you can, you can isolate the bad cylinder with a timing light (find out which cylinder is not firing consistantly.) I have tried that, and why I changed the plug wires and that one NEW plug. Last thing on my list is the coil Zach |
VaccaRabite |
Coils usually either work or don't work. I've not heard of coils being intermitent.
If you pull the plug and look at the tip, what does it look like? Is it a nice brown color, or wet and black? What kind of dizzy do you have? If points, are you sure that your points are set and dwell is correct? Zach |
indianmort |
Newbie ![]() Group: Members Posts: 14 Joined: 2-August 10 From: sugarloaf ny Member No.: 12,004 Region Association: None ![]() |
if the misfire develops after the car has warmed up, it could be the coil. when cold it could run fine, as the coil heats up, it expands. if there is a failure in the windings as it expands the wires separate and the coil breaks down.
Borderline |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California ![]() |
How did you synch the carbs/linkage? I have found that spending additional time with the linkage can make all the difference. I synch the carbs twice. The first time is at idle with one of the links removed. The second time I synch the carbs with both links installed. I tighten the adjuster nut on the throttle cable to bring the engine speed up to 1500 - 2000 rpm. I then use the unisyn to check flow on both carbs and adjust the links to balance it again. When this is done properly the engine smooths out and runs great! You spend a lot of time at partial throttle when you're cruising on the street and hwy, having the carbs synched there really helps. FWIW (IMG:style_emoticons/default/biggrin.gif)
Razorbobsr |
Coils usually either work or don't work. I've not heard of coils being intermitent. If you pull the plug and look at the tip, what does it look like? Is it a nice brown color, or wet and black? What kind of dizzy do you have? If points, are you sure that your points are set and dwell is correct? Zach |
Razorbobsr |
How did you synch the carbs/linkage? I have found that spending additional time with the linkage can make all the difference. I synch the carbs twice. The first time is at idle with one of the links removed. The second time I synch the carbs with both links installed. I tighten the adjuster nut on the throttle cable to bring the engine speed up to 1500 - 2000 rpm. I then use the unisyn to check flow on both carbs and adjust the links to balance it again. When this is done properly the engine smooths out and runs great! You spend a lot of time at partial throttle when you're cruising on the street and hwy, having the carbs synched there really helps. FWIW (IMG:style_emoticons/default/biggrin.gif) |
Razorbobsr |
if the misfire develops after the car has warmed up, it could be the coil. when cold it could run fine, as the coil heats up, it expands. if there is a failure in the windings as it expands the wires separate and the coil breaks down. When you say, breaks down........ Just how would that sound/feel. The spark at idle is blue and strong, jumps 3/4 of an inch. Bob |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
009 Dizzy is garbage. As Dave Darling loves to say, "Give it the float test. Throw it in a lake and if it floats, it's good." The problem your having sounds like typical 009 problems. With the 009 it either idles great, but sucks a WOT, or runs great at WOT and has crap idle.
I also agree about synching the carbs. If you've got some extra cash, just toss out the cross bar linkage and get a CSP Bellcrank. Otherwise, it's takes a lot of trial and error and a lot of fidgeting to get the cross bar linkages to work right. |
Razorbobsr |
009 Dizzy is garbage. As Dave Darling loves to say, "Give it the float test. Throw it in a lake and if it floats, it's good." The problem your having sounds like typical 009 problems. With the 009 it either idles great, but sucks a WOT, or runs great at WOT and has crap idle. I also agree about synching the carbs. If you've got some extra cash, just toss out the cross bar linkage and get a CSP Bellcrank. Otherwise, it's takes a lot of trial and error and a lot of fidgeting to get the cross bar linkages to work right. Why is the 009 junk? CPS Bellcrank?? Why are cross bars a pain? Would rather not change parts till I find the right combo, kinda costly and I am CHEAP!! LOL On the face of it this prob sounds simple, miss fires.............. Changed plugs and wires, cleaned cap...... Bob |
McMark |
Normally I retype all this info. But there is so many posts about 009s and recently the CSP vs. Crossbar info. Check out the search function at the top of the page.
Really simplified: 1. The 009 doesn't have enough total advance. It's like a bed sheet that's too short. It covers your feet, or it covers your body, but not both at the same time. 2. The crossbar linkage has too many moving parts that can introduce slop, the parts are never manufactured to any sort of tight tolerance, and so even when it's set up as well as possible it's still easy to open one carb and not the other. The ideally perfect linkage would never, ever, ever allow that to happen. The CSP is much closer to that ideal than any of the cross bar linkages. |
Razorbobsr |
Normally I retype all this info. But there is so many posts about 009s and recently the CSP vs. Crossbar info. Check out the search function at the top of the page. Really simplified: 1. The 009 doesn't have enough total advance. It's like a bed sheet that's too short. It covers your feet, or it covers your body, but not both at the same time. 2. The crossbar linkage has too many moving parts that can introduce slop, the parts are never manufactured to any sort of tight tolerance, and so even when it's set up as well as possible it's still easy to open one carb and not the other. The ideally perfect linkage would never, ever, ever allow that to happen. The CSP is much closer to that ideal than any of the cross bar linkages. CPS link? How much advance is correct? Bob |
Razorbobsr |
VaccaRabite |
Always adjust carbs when they are fully warmed up. Adjusting them while cold will make them run fast when warm.
On the mix screw Turning in closes the the jet (less fuel and air) Turning out opens the jet (more fuel and air) the mix screw does not change the ratio of air to fuel, just the volume of it. The object of adjusting this screw is to get the cylinder to run smoothly on as little fuel and air as possible. Turning the idle screw changes the idle speed for that bank of carbs. You disconnect the bar by unbolting the drop links that go from the cross bar to the carb body. They are usually held on with small bolts (m4 or m5). Depending on the make of the bar, some have snap joints instead of bolts. Take a picture of your connection and we can help you out. Also, try to be a little more clear when you post. It may just be me, but I have a hard time understanding what you are trying due to your posting style. Zach |
McMark |
QUOTE On the mix screw Turning in closes the the jet (less fuel and air) Turning out opens the jet (more fuel and air) the mix screw does not change the ratio of air to fuel, just the volume of it. The object of adjusting this screw is to get the cylinder to run smoothly on as little fuel and air as possible. Zach, you're confusing two screws here. The idle mixture screws cange only the volume of fuel at idle. Screwing them in will make it run leaner, out is richer. This screw does not change airflow at idle. Right next to the idle mixture screw is an air bypass screw. This one has a lock nut on it and it changes that amount of air bypassing the throttle plate at idle. Screwing it out allows more air to pass, and in allows less. The air bypass screws need to be adjusted while the linkage is disconnected and with a UniSyn or Synchometer (better). The function of the air bypass screws is not to change mixture, but to equalize the air flow of the two throats. QUOTE You disconnect the bar by unbolting the drop links that go from the cross bar to the carb body. They are usually held on with small bolts (m4 or m5). Depending on the make of the bar, some have snap joints instead of bolts. Take a picture of your connection and we can help you out. (IMG:style_emoticons/default/agree.gif) |
Razorbobsr |
Always adjust carbs when they are fully warmed up. Adjusting them while cold will make them run fast when warm. On the mix screw Turning in closes the the jet (less fuel and air) Turning out opens the jet (more fuel and air) the mix screw does not change the ratio of air to fuel, just the volume of it. The object of adjusting this screw is to get the cylinder to run smoothly on as little fuel and air as possible. Turning the idle screw changes the idle speed for that bank of carbs. You disconnect the bar by unbolting the drop links that go from the cross bar to the carb body. They are usually held on with small bolts (m4 or m5). Depending on the make of the bar, some have snap joints instead of bolts. Take a picture of your connection and we can help you out. Also, try to be a little more clear when you post. It may just be me, but I have a hard time understanding what you are trying due to your posting style. Zach Could be my lack of formal education?? Or the British sports car guys dumbed me down?? Or just natural? Will try to do better! Cleaned D/cap with carb cleaner, buffed rotor and cleaned, backed idle on carbs all the off, in till I picked up a hair of RPMs then backed off 1/2 hair. Backfires much more muffeled now, poom V BANG Better............ AA guys tell me I have TOO open exhaust sys and need more back pressure, cherry bomb muffler just about stright through...... Correct?? Bob |
VaccaRabite |
Zach, you're confusing two screws here. The idle mixture screws cange only the volume of fuel at idle. Screwing them in will make it run leaner, out is richer. This screw does not change airflow at idle. Right next to the idle mixture screw is an air bypass screw. This one has a lock nut on it and it changes that amount of air bypassing the throttle plate at idle. Screwing it out allows more air to pass, and in allows less. The air bypass screws need to be adjusted while the linkage is disconnected and with a UniSyn or Synchometer (better). The function of the air bypass screws is not to change mixture, but to equalize the air flow of the two throats. (IMG:http://www.914world.com/bbs2/uploads_offsite/th192.photobucket.com-1435-1300325684.1.jpg) WTF was I thinking? I seriously need to get out and play with my car, I am way out of practice here. Razor, From your other post, I think you are using a Eurorace header. If it has the turbo muffler, there is not much going on inside it. Part of the reason its so loud. Zach |
Lo-Fi Version | Time is now: 6th July 2025 - 05:27 AM |
