Shop etiquette |
Shop etiquette |
patssle |
Mar 14 2011, 12:57 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I'm going to take my 914 in this week to the shop to get the transmission rebuilt. I've never had anybody work on that car before, so it'll be a first.
The tranny is pretty gunky at the botton due to leaks and my attempts to plug the leaks. Is it appropriate to clean it before going in, or is it expected for old cars to be full of crud? Only thing I worry about is cleaning will open up the leaks and create a gusher - the shop is 60 miles away. Might sound silly, but just curious what others do. |
montoya 73 2.0 |
Mar 14 2011, 01:04 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
I would ask the shop what they prefer. Some shops will charge you for cleaning up.
jimkelly |
Mar 14 2011, 01:05 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
must be pretty bad : )
to be considerate - call the shop and/or send them a few pics. i can't imagine any shop asking you to clean it before bringing it in. jim |
Sawfish |
Mar 14 2011, 01:08 PM
Newbie Group: Members Posts: 43 Joined: 28-January 09 From: San Diego Member No.: 9,990 Region Association: Southwest Region |
I'm going to take my 914 in this week to the shop to get the transmission rebuilt. I've never had anybody work on that car before, so it'll be a first. The tranny is pretty gunky at the botton due to leaks and my attempts to plug the leaks. Is it appropriate to clean it before going in, or is it expected for old cars to be full of crud? Only thing I worry about is cleaning will open up the leaks and create a gusher - the shop is 60 miles away. Might sound silly, but just curious what others do. In my opion it is in your best interest as well as being the right thing to do. Your mechanic may not complain about a dirty engine however in order for him to give you quality work it must be cleaned. If you clean it as much as you can first then your ulitmatley payng your mechanic for his experience and knowledge rather than paying him to do the dirty job. Just my two cents. the flip side is does the mess underneath streamline the mechanics abiltity to diagnose and isolate your specific issue. Good luck |
markb |
Mar 14 2011, 01:11 PM
i can't imagine any shop asking you to clean it before bringing it in. jim (IMG:style_emoticons/default/agree.gif) |
Spoke |
Mar 14 2011, 01:15 PM
I'd pull the trans out of the car in my garage then clean the case and take it in.
JRust |
Mar 14 2011, 01:36 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) . If they are only doing your transmission. Pull it clean it & take it in. IF you plan to have them do other work then take it in. While cleaning it up some would be nice it isn't critical. The points made above are sound. In the long run it will cost you less if it is cleaned before hand.
rick 918-S |
Mar 14 2011, 01:37 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
If it were me I would at least give it a quicky. $ 10.00 at the self serve car wash vs what... $90.00 hr.shop rate? I would have to charge you shop labor rates to clean the thing in order to fine the leak. I doubt your mechanic will care if you clean it first. Your not going to make it perfect at the self serve but getting the first layer off will help.
orange914 |
Mar 14 2011, 02:10 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
40 years of baked on engine and trans oil doesn't clean off easily. unless you want to pay a fortune or be dissatisfied with a bad clean up (grim hides leaks), i'd do it first.
more often than not, i've found a dirty car (exterior) even encourages that level repair. |
patssle |
Mar 14 2011, 02:15 PM
Thanks guys!
Is using a pressure washer ok or does that force water into the tranny, especially with it being a leaky tranny? *goes to search* |
orange914 |
Mar 14 2011, 02:23 PM
Thanks guys! Is using a pressure washer ok or does that force water into the tranny, especially with it being a leaky tranny? *goes to search* if your taking it in right away, i wouldn't worry about a carefully blasted case. i used to always soak really grungy areas with wd40 an hour or two before steam cleaning, you'd be surprised how well that soaks in and loosens the touch stuff. just get it off before it dries. |
Cairo94507 |
Mar 14 2011, 02:30 PM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Personally, I think it is the right thing to do to make it easier for the mechanic to see what he has got and make it a cleaner job for you.
If he pulls the transaxle, I would ask if he has the ability to clean it up nice, all the areas you may not be able to get while it is in the car, before it goes back into the car. Then see if you can come in and clean the area of the car above the transaxle yourself while it is out of the car. |
SLITS |
Mar 14 2011, 02:34 PM
If pressure washing, wrap vent with tape to avoid getting water inside tranny.
GeorgeRud |
Mar 14 2011, 03:05 PM
I can't think of any mechanic that wouldn't appreciate you cleaning the junk off the trans.
There really aren't all that many places that trannies leak from, and I assume he will be addressing them all wwhen he's working on the trans. |
McMark |
Mar 14 2011, 03:35 PM
(IMG:style_emoticons/default/agree.gif) Cleaning is expensive. I don't expect people to clean up, but it sure is nice when I get to work on a clean engine/trans.
zymurgist |
Mar 14 2011, 03:40 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I had a well respected musclecar guy go over the T-10 in my Corvette. I cleaned the tranny before I handed it over to him. Of course it was out of the car at the time.
Root_Werks |
Mar 14 2011, 03:50 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
In my experience, the nicer condition something is before you do the hand-off, the better the other party will care for it.
Took my POS squareback in to get it aligned months back. Cleaned it, spottless, nothing anywhere. Looked great. Got it back that way. The shop guy had put a seat cover and floor mat cover in it. Made sure to leave them in the car so I'd see them. Toss a mechanic a greasy heap of parts or crusty tranny, they'll think you don't care THAT much about it. So what's the big beef if it comes back to you not 100% clean or if it get's kicked around the shop floor for a while? Or sits outside until they have room and time to work on it? |
monkeyboy |
Mar 14 2011, 04:48 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Since you don't want that crud inside your trans, someone has to clean it.
I know my old ATV engine builder would tell you up front that if you brought it in dirty, you would be charged for a cleaning. He needed clean parts. |
Dr Evil |
Mar 14 2011, 07:11 PM
Knock off the chunks. Most people do that before they send their transmissions to me. If you are paying a shop to pull and rebuild your transmission then you must have $$ so dont worry about a dirty box (IMG:style_emoticons/default/wink.gif) Shops charge a huge amount for the build.
ripper911 |
Mar 14 2011, 07:16 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I once got a complaint from the shop that "you couldn't even tell there was an engine in there".
I do drive my car everyday, no matter the weather. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:17 PM |
