That sorry bitch!, Christine stranded me in Nashville! |
hot_shoe914 |
Mar 20 2011, 11:22 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Okay, as you all know, Christine...aka Resses Cup, friend of Buttercup, left my ass stranded in Tennessee tonight in the middle of no where and all I could hear was banjo Music! I was heading back to Memphis from Nashvile, had just run the hell out of some sweet twisties, I pull into the gas station to wash my windshied. I shut her off, did the windows, get in, fire her up, and before I can put her in gear she quits! (IMG:style_emoticons/default/WTF.gif) Fuel pump is working, motor spins good but no starting, (IMG:style_emoticons/default/confused24.gif) Mess with it awhile, checking things over and soon I have it where the fuel pump no longer kicks in. (IMG:style_emoticons/default/hissyfit.gif) I relax, listen to the banjo music, and finally get the pump working again. I get in, hit the key, she fires right up. (IMG:style_emoticons/default/aktion035.gif) Unfortunately I hear a strange noise so I shut her off. Check a few things, hit the key, fires right up again. (IMG:style_emoticons/default/aktion035.gif) Sadly I hear the noise again and shut her off. (IMG:style_emoticons/default/sad.gif) Do some more checking, look underneath, find nothing so I try to start her up again. FP works, bitch no starts. (IMG:style_emoticons/default/headbang.gif) Repeat all the crap from the first go around with same results so I say screw it and pack up all my stuff. Hit the key and she fires right up again! (IMG:style_emoticons/default/idea.gif) I hop in, take off down the road and get less than a mile before the slut quits again in the middle of pitch darness on the side of a hill. (IMG:style_emoticons/default/mad.gif) As I am working on her in the middle of the highway, one of the "banjo" people show up, he has apparently followed me. Very strange fellow, but that is another whole story in it self. Car runs smooth for a moment, the starts lurching and bucking and cutting out as it did before it quit. I limp it back to a station, call my friend to come get me before the Deliverance boys find me again. I leave car idling for awhile, still not running right. While I am waiting on my friend to show up, banjo boy comes back again (thought I had lost him) but fortunately he doesn't get out of his truck, and finally drives off. Friend shows up, we decide to try and limp it 12 miles back to his house. On the way back she did the same lurching and bucking as before but seemed to get better and better the farther we went. Actually was running pretty decent by the time we got back with the exception of take off and a cut out once in awhile. Thought about heading back again but decided against it. In the morning I am going to swap coil, points, and fuel filter and hope for the best. Seems electrical to me and not fuel, but going to change filter to be sure. Any other ideas, comments or suggestion? (IMG:style_emoticons/default/confused24.gif)
Shoe p.s. Stock '73 2.0L with D-jet. |
silver74insocal |
Mar 20 2011, 11:27 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
i have read about this same issue caused by the condenser on the dizzy. im not speaking from experience but something to bring with you if you have a spare, good luck (IMG:style_emoticons/default/beerchug.gif) DAve
P.S. do you got a real purty mouth? (IMG:style_emoticons/default/happy11.gif) |
914_teener |
Mar 20 2011, 11:31 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
i have read about this same issue caused by the condenser on the dizzy. im not speaking from experience but something to bring with you if you have a spare, good luck (IMG:style_emoticons/default/beerchug.gif) DAve P.S. do you got a real purty mouth? (IMG:style_emoticons/default/happy11.gif) Go through Brad Anders list before you start swaping stuff. You don't say wether you had spark or not. |
hot_shoe914 |
Mar 20 2011, 11:34 PM
i have read about this same issue caused by the condenser on the dizzy. im not speaking from experience but something to bring with you if you have a spare, good luck (IMG:style_emoticons/default/beerchug.gif) DAve P.S. do you got a real purty mouth? (IMG:style_emoticons/default/happy11.gif) Go through Brad Anders list before you start swaping stuff. You don't say wether you had spark or not. She currently cranks right up, just very rough idle and sluggish off line. |
moparrob |
Mar 20 2011, 11:40 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
30 years ago my teener did that and it ended up being the retainer for the distributor breaker plate, of all things. The ball and arm/socket assembly was just about to snap off but was causing erratic timing changes in the interim. I had people tell me it needed everything from a new F.I. brain to new injectors but they had no idea.
Then I met Mike Dalton, who quickly diagnosed it and became my mechanic for many years. Now he is on to bigger and better things. (ISI Shootists) |
bugsy0 |
Mar 20 2011, 11:42 PM
Member Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None |
CHT sender?
914_teener |
Mar 20 2011, 11:47 PM
30 years ago my teener did that and it ended up being the retainer for the distributor breaker plate, of all things. The ball and arm/socket assembly was just about to snap off but was causing erratic timing changes in the interim. I had people tell me it needed everything from a new F.I. brain to new injectors but they had no idea. Then I met Mike Dalton, who quickly diagnosed it and became my mechanic for many years. Now he is on to bigger and better things. (ISI Shootists) Yea...could be a lot of things. Could be the ground on the retainer plate or a MPS going back....sounds like what my car did....but...if it were the MPS it would usually act like it is flooded. So without methodically checking it out...it is hard to say. |
Bruce Hinds |
Mar 20 2011, 11:49 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
almost sounds like water and crap in the fuel.... perhaps the twisties unsettled stuff from the sump of the tank. Water going through the pump will make is sound different(actually hear it).
Water and crud will make it run rough and buck and now even if that crap has settled back down, you may still have the injectors clogged. It would be easy to pull a fuel line and stick it in a jar, turn on the key and see what you're pumping. This ethanol is crap, it can hold moisture in suspension until it's supper saturated and then you've got troubles. |
914_teener |
Mar 20 2011, 11:50 PM
30 years ago my teener did that and it ended up being the retainer for the distributor breaker plate, of all things. The ball and arm/socket assembly was just about to snap off but was causing erratic timing changes in the interim. I had people tell me it needed everything from a new F.I. brain to new injectors but they had no idea. Then I met Mike Dalton, who quickly diagnosed it and became my mechanic for many years. Now he is on to bigger and better things. (ISI Shootists) Yea...could be a lot of things. Could be the ground on the retainer plate or a MPS going back....sounds like what my car did....but...if it were the MPS it would usually act like it is flooded. So without methodically checking it out...it is hard to say. Yep...could be the CHT as well......bypass to ground to see if it is running.. or check the ohms with your handy dandy Multi-meter. Sounds a little like deliverance to me (IMG:style_emoticons/default/unsure.gif) |
Mar 21 2011, 12:21 AM
Pull the plug wires, one at a time, while the engine is idling. That will tell you if you have a dead hole; pulling that plug wire won't change the way the engine runs.
Slap a timing light on and see if the timing jumps all over. That indicates a problem in the distributor. Check the fuel as was suggested. Try checking the delivery of the fuel; you can put them in jars and watch while someone cranks the starter. You want a cone-shaped spray, not dribbles and not a stream. Check all the electrical connections in the engine bay. These are all cheap/free things to check. Make sure you figure out where the problem is before you start throwing parts at it. --DD |
Mary Shortridge |
Mar 21 2011, 05:27 AM
Member Group: Members Posts: 221 Joined: 27-July 09 From: Garden City, KS Member No.: 10,616 Region Association: Rocky Mountains |
Quit calling that girl names! (IMG:style_emoticons/default/biggrin.gif)
Bartlett 914 |
Mar 21 2011, 05:40 AM
almost sounds like water and crap in the fuel.... perhaps the twisties unsettled stuff from the sump of the tank. Water going through the pump will make is sound different(actually hear it). Water and crud will make it run rough and buck and now even if that crap has settled back down, you may still have the injectors clogged. It would be easy to pull a fuel line and stick it in a jar, turn on the key and see what you're pumping. This ethanol is crap, it can hold moisture in suspension until it's supper saturated and then you've got troubles. That was my first thought as well. |
SUNAB914 |
Mar 21 2011, 06:30 AM
Senior Member Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
Yea, I would say something in fuel or clogging. Funny story though, be there in the same situation, lost a girlfriend because of it too.
IronHillRestorations |
Mar 21 2011, 07:47 AM
Check the FI trigger points
cooltimes |
Mar 21 2011, 09:05 AM
Advanced Member Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None |
Potato or banjo plunker's mystery of being seen too often crammed in the exhaust.
Need a hand getting back home? All I have is my94 Corolla but I can pick you up and take you wherever for parts, home, etc. Not feasible for towing but can try if it gets around to that. Call me. Jackson area code plus 42592zero1 MikeCool |
hot_shoe914 |
Mar 21 2011, 10:02 AM
Potato or banjo plunker's mystery of being seen too often crammed in the exhaust. Need a hand getting back home? All I have is my94 Corolla but I can pick you up and take you wherever for parts, home, etc. Not feasible for towing but can try if it gets around to that. Call me. Jackson area code plus 42592zero1 MikeCool Thanks Mike, I currently haven't found out what is wrong, but she is back to running and purring like a kitten. I will save your number in my phone just in case. If she makes Jackson okay maybe you'd like to meet for coffee or something. I checked fuel filter and it was clean as a whistle. Checked points only to find out I didn't have any. Hopefully she will continue to run smooth enough to get me home. I will definitely call on you if I don't make it and get close to you. Shoe |
bandjoey |
Mar 21 2011, 10:09 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
You took her picture off your Avatar and she's looking for revenge! Kiss her, stroke her, fondle her, but not in front of a banjo picker in Tennessee - and she'll probably come around your way again. (IMG:style_emoticons/default/wub.gif)
cooltimes |
Mar 21 2011, 10:44 AM
Hoping the babe is running like it should but here if you need me.
Exit 83 turn on North Campbell st exit. Exxon Station there and good BBQ. Call me and I'll be there in 5 to 10 minutes and buy you a BBQ. state champion Cajun Cooker served there. Looking in my what's left old pile of 914 and took this pix. All used but welcome to any or ALL of it. It was left over from my 1.8 and 1.7 days. Did have a new set of points but didn't find them. Mike EDIT: Will escort behind you to Memphis if that will ease the mind. 914 teener in Tennessee remembering I had 914 help when I need it. Beep Beep Potato or banjo plunker's mystery of being seen too often crammed in the exhaust. Need a hand getting back home? All I have is my94 Corolla but I can pick you up and take you wherever for parts, home, etc. Not feasible for towing but can try if it gets around to that. Call me. Jackson area code plus 42592zero1 MikeCool Thanks Mike, I currently haven't found out what is wrong, but she is back to running and purring like a kitten. I will save your number in my phone just in case. If she makes Jackson okay maybe you'd like to meet for coffee or something. I checked fuel filter and it was clean as a whistle. Checked points only to find out I didn't have any. Hopefully she will continue to run smooth enough to get me home. I will definitely call on you if I don't make it and get close to you. Shoe This post has been edited by cooltimes: Mar 21 2011, 11:01 AM |
Mar 21 2011, 11:13 AM
Quit calling that girl names! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) |
Dr Evil |
Mar 21 2011, 11:44 AM
That station puts water in the gas and then waits for your car to stall before banjo-boy makes off with you into the woods for some sweet, sweet mouth lovin (IMG:style_emoticons/default/sheeplove.gif)
Check your fuel. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:58 PM |
