EFI for 1k, programable |
Mar 27 2011, 03:00 PM
Custom Member Group: Members Posts: 24,562 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Does it exist yet?
Ideally, 1k for ITB's, EFI and harness. Anyone...and no Megasquirt please.. Looking for something to start with...then like any good drug, get hooked and pay more to play. Rich |
Mark Henry |
Mar 27 2011, 04:58 PM
No.
jd74914 |
Mar 27 2011, 06:36 PM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. |
CG-914 |
Mar 27 2011, 07:09 PM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. are there links for these? |
Mar 27 2011, 07:23 PM
(IMG:style_emoticons/default/agree.gif) You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. are there links for these? Seriously? You have heard of Google, right? Rich |
echocanyons |
Mar 27 2011, 07:44 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Double that number & this is an option, although I know of nobody who has used this.
You can check their catalog, they do have a 914 ultra competition FI system for sale. Attached image(s) |
Mike Bellis |
Mar 27 2011, 08:52 PM
Double that number & this is an option, although I know of nobody who has used this. You can check their catalog, they do have a 914 ultra competition FI system for sale. This is the cheapest option out there. A complete system for $1700. You will spend more on Megasquirt and misc parts to fab up a system. Plus this system looks cool. |
JamesM |
Mar 27 2011, 09:29 PM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
If you want to stay anywhere near that price Megasquirt is your only option. The cheapest ITB's I know of (that are actually made for our appliction) are the cb performance 48MMs but those are still $530 just for the pair of bare TB's. Add injectors, fuel rails, manifold, linkage, velocity stacks, filters, and a TPS and you are already close to 1k before even looking at an ECU or harness.
Using MS as the ECU you could pull it off for around 1k, anything else and best case is about twice that. What are you currently running carbs or d-jet, and what is your reason for wanting to go to aftermarket injection? Does it exist yet? Ideally, 1k for ITB's, EFI and harness. Anyone...and no Megasquirt please.. Looking for something to start with...then like any good drug, get hooked and pay more to play. Rich |
JamesM |
Mar 27 2011, 09:33 PM
I am not to familar with the others but from what i remember the Spectre EMS pro IS a Megasquirt 1 based ECU. Whenever you see a low cost ECU look really close, good change it is megasquirt based.
(IMG:style_emoticons/default/agree.gif) You can buy a number of entry level ECU's with harnesses for <$1k, but ITB's are definately not going to come in under that mark. ITB's are expensive enough that In fact, unless you adapter motorcycle throttle bodies, I am condident you would spend more than that piecing together a MS system with them. Off the top of my head, Adaptronic, DTA, Performance Electronics, and Spectre (EMS Pro) all offer resonably priced ECU's. Also, at the pricepoint you are looking at, I really wouldn't discount pre-assembled MS units or Microsquirts. The last MS product I played with was 2.5+ years ago and I wasn't super impressed by the quality, but from what I have seen of late, they seem to be maturing into extremely nice products. Part of my disatisfaction was post likely related to my inexperience. Right now I have friends whose DD's run with them. I do like the Adaptronic e420C, the one on our racecar has been bulletproof, its only limitation is the lack of individual cylinder trim, and a slightly different correction tabel setup. |
jd74914 |
Mar 27 2011, 09:42 PM
Yep. It is MS1 based. Maybe I'm looking at it the wrong way, but while MS-based, it does have a warranty so I don't consider it the same. When people say they don't want MS, I usually assume their aversion is because of the lack of factory support.
The others are not at all related to MS. This is totally OT, but, if anyone here is into controls and really wants to go hardcore custom with their engine controls look into the Adaptronic e1280. It has custom function scripting ability. This isn't a paid plug (IMG:style_emoticons/default/laugh.gif) , just a satisfied customer, but I would recomend the Adaptronic stuff if anyone wants to spend a bit more money. I've dealt with the guys at Adaptronic, and they are awesome. Even though they are located in Oz so the timezones are really spread, they have answered and question we (my FSAE team) have had in literally a matter of hours. |
wertygrog |
Mar 27 2011, 10:31 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
I did a Megasquirt setup on my type 4 turbocharged sand rail for well under 1 kilodollar and it works great. I took the venturis out of my 40IDF's and BAM there's your ITB's.
jd74914 |
Mar 27 2011, 11:39 PM
If you already have carbs thats a great solution. (IMG:style_emoticons/default/smile.gif) My dad and I are planning on doing that with his 911's Zeniths so we can stealthily retrofit EFI.
Mar 28 2011, 08:16 AM
underthetire |
Mar 28 2011, 08:28 AM
A guy at work just gave me some 41MM TB's off a GSXR. Looking for webber intakes now to update my MS2.
ConeDodger |
Mar 28 2011, 09:02 AM
Apex killer! Group: Members Posts: 23,558 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I would guess I have $750 in Jenvey TB's, + some EFI components used such as TPS, injectors, etc. Another $1250 to SDS for the system with harness delete. About $500 so far to Jeff Bowlsby to build a custom harness. Some misc. stuff that isn't cheap but I can't think of now...
gothspeed |
Mar 28 2011, 10:44 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
The CB option as stated above, is very inexpensive IMO ......... it may even be possible to remove manifolds and linkage from the kit to get a better price, if one already has them.
http://www.cbperformance.com/catalog.asp?ProductID=1665 |
Randal |
Mar 28 2011, 11:19 AM
Double that number & this is an option, although I know of nobody who has used this. You can check their catalog, they do have a 914 ultra competition FI system for sale. What a great deal. People I know that have utilized CB performance engines are happy, but in any event you should ask CB performance for references. FYI when we put FI on "222" we were plowing new ground. We used the Link System from New Zealand. Paul Harvey, Performance Development, did the harness (*), which was developed from scratch, we used TWM throttle bodies and fuel rails. There are braided and high pressure lines everywhere all of which cost $$. Of course we needed a high pressure fuel regulator, filter and very high performance fuel pump, plus all the other accessories, i.e., 02 sensors, etc. We use CB maniforlds. And then we had the nose bleed of developing a fuel map on the dyno which costs, in itself, more than twice what CB charges for their entire system, let alone all the HW. The CB approach looks to be a very cost effective and a huge positive is that it is "matched," i.e., the homework is done. If you went this way you should seriously consider having them do the initial tuning as well. (*) I have the diagrams if you'd like to see them PS The most positive thing about FI is that once it is done, your done. No more messing with tuning regardless of where you are, i.e., sea level or off running a hill climb at 5000 feet. |
Mike Bellis |
Mar 28 2011, 11:39 AM
MS based systems (and others) also require a laptop computer and a lot of trial and error tuning the system. The CB system claims a plug and play adaptability.
I have made fuel and ignition maps from scratch. Not a bunch of fun but can be rewarding when it runs right. It is very time consuming. |
Mark Henry |
Mar 28 2011, 12:16 PM
Nothing beats SDS for ease of tuning. Nothing
thelogo |
Mar 28 2011, 12:37 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Double that number & this is an option, although I know of nobody who has used this. You can check their catalog, they do have a 914 ultra competition FI system for sale. and what about the quote : simple f/ i kit from / laptop less ! cb http://www.cbperformance.com/catalog.asp?ProductID=278 |
Lo-Fi Version | Time is now: 25th April 2024 - 09:55 AM |
