> alternator not charging
biker bob
post Apr 6 2011, 02:47 PM
Started the car (72 2.0 L) this morning to go for gas. Alternator light stayed on for about 15 seconds after engine started then went out. Restarted the engine after getting gas and the light went out. Returned home no issues. Restarted engine after about 30 minutes. The alternator light came on and would not go out. Drove around the block and light remained on. Checked charging at battery NO charging.
2000 miles on new belt, new Bosche alternator,and new Bosche voltage regulator. Alternator wires properly plugged into the relay board. Belt properly adjusted. Transmission ground strap clean and tight. Help needed.
- Lo-Fi Version Time is now: 16th July 2025 - 03:37 AM
