I'm slightly confused!, I know, whats new??? |
mike_the_man |
May 5 2004, 11:41 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
I'll give it a try. This could be my problem. Here's hoping!
Bruce Allert |
May 5 2004, 12:11 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
mike_the_man |
May 5 2004, 12:55 PM
Will do Bruce, thanks for all the suggestions guys! I've said it before, and I've said it again, this board rocks!!! (IMG:style_emoticons/default/aktion035.gif)
mike_the_man |
May 6 2004, 09:07 AM
The idea of my dizzy being 180 degrees out seemed like a very likely one to me, put after messing with it last night, I don't think thats the problem. The dizzy will only go in one way. Not matter how much I jiggled it or wiggled it, there was no way I could get the rotor in 180 off. So, I'm quite sure that the dizzy orientation isn't the problem. I also took one of my spare MPS's and tried to lean out the mixture by tightening the small inside adjuster screw and the car ran worse and worse till it finally stalled out.
I'm thinking that the problem has something to do with the ignition system. But I'm stumped as to what I should look at next. Ideas? |
nebreitling |
May 6 2004, 11:08 AM
i assume your coil is good?
mike_the_man |
May 6 2004, 11:16 AM
Tried two different coils, no change. Different plug wires, cap and rotor, no change. (IMG:style_emoticons/default/confused24.gif) Could fouled plugs cause this big of a problem? One of the only things left that I can think of.
nebreitling |
May 6 2004, 11:21 AM
fouled plugs can do all sorts of crap, and runing über-rich for a while will certainly foul your plugs. change 'em, it's cheap.
F4i |
Jul 10 2004, 08:34 PM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
This is the exact problem I am currently having. Was a solution found? Please let me know. Here or PM Thanks.
(IMG:style_emoticons/default/pray.gif) |
F4i |
Jul 11 2004, 04:56 PM
Bump
AlexO |
Jul 11 2004, 07:26 PM
Member Group: Members Posts: 55 Joined: 27-March 03 From: Lake Elsinore, CA Member No.: 482 |
If I remember right (I havent worked on the teener in over two years) the dizzy can be built 180 off. If so, it'll index properly, but the top and bottom shafts will be 180 off causeing the rotor to be the same.
Just throwing ideas out.... --Alex |
F4i |
Jul 11 2004, 07:37 PM
I had thought that as well. I have another post which asks which way it goes in relation to the rotor. Does anyone know?
Thanks |
ChrisFoley |
Jul 11 2004, 10:43 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The only way to move the distributor 180 degrees is to remove the distr. drive shaft below first.
I don't think that's your problem. Did you set the timing with the distr. vac. lines removed and plugged? I have worked on engines where the retard line was disconnected and plugged, and when I reconnected it the timing got all screwed up and the engine wouldn't run right anymore. Must be due to a vac. leak or something. A vacuum leak will cause the MPS to send the wrong signal to the ECU. I agree that checking the CHT sensor (and in-line resistor if you have one) is a good idea too. |
F4i |
Jul 12 2004, 10:54 PM
When setting the timing should the vac lines or ports be plugged? I thought the just had to be off and left open.
mike_the_man |
Jul 13 2004, 10:46 AM
I believe that the vac lines should be plugged. It's probably not a big deal either way, but it will be a small vaccuum leak. The ports on the dizzy canister should be left open. Do you have both vaccum advance and retard, or just the retard port?
F4i |
Jul 13 2004, 04:59 PM
I have both because I opened the advance port on the TB. Is it possible I have not enough back Px due to a crappy old muffler? I have a bursch on the way. Is it possible that there is too much retard. It really wants to die when it is hooked up. Everything else on the fi checks out. I have the exact same symptoms as mike - the backfiring. I am completely open to ideas and opinions(related;)
Thanks |
Lo-Fi Version | Time is now: 15th May 2024 - 03:21 PM |
