BUILD-OFF CHALLENGE: Another 914-GT Conversion Project, I finally drove it this weekend! |
jkb944t |
Apr 14 2011, 05:55 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am working on restoring a 1973 914 and converting it to a GT clone with the flares and chassis stiffening. Here is a picture of where I am on it.
Jeff B Attached image(s) |
jkb944t |
Apr 14 2011, 06:03 AM
I can see rust inside the center tunnel but it is still solid. What would be the best way to approach addressing this rust so that it doesn’t get any worse? Here are some pictures of the rust that I have in the center tunnel.
jasons |
Apr 14 2011, 11:31 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I can see rust inside the center tunnel but it is still solid. What would be the best way to approach addressing this rust so that it doesn’t get any worse? Here are some pictures of the rust that I have in the center tunnel. Jeff B I don't know if its best, but I sprayed Ospho up down my tunnel. I had already cut an access hole to fix the clutch tube and that helped me get better distribution. Honestly, I'm not sure what else you can do? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 07:45 AM |
