BUILD-OFF CHALLENGE: Another 914-GT Conversion Project, I finally drove it this weekend! |
jkb944t |
Apr 14 2011, 05:55 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am working on restoring a 1973 914 and converting it to a GT clone with the flares and chassis stiffening. Here is a picture of where I am on it.
Jeff B Attached image(s) |
jkb944t |
May 14 2015, 10:46 AM
I made some more progress this week. I finally got the front tow hook fabricated and welded the nuts in place.
Then I welded it to the lower front valence that I had reinforced previously. Test fit the modified tow hook in place and everything fit perfectly. The next item to work on is the battery tray assembly. I think I will keep it in the stock location but modify it so that I can bolt it in instead of welding it in. That should make painting the area easier and allow me to remove it if necessary. I saw it was done this way on the 914-6 GT website. Any thoughts on this idea are welcomed. Jeff B |
Lo-Fi Version | Time is now: 10th May 2024 - 08:53 AM |
