BUILD-OFF CHALLENGE: Another 914-GT Conversion Project, I finally drove it this weekend! |
jkb944t |
Apr 14 2011, 05:55 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am working on restoring a 1973 914 and converting it to a GT clone with the flares and chassis stiffening. Here is a picture of where I am on it.
Jeff B Attached image(s) |
jkb944t |
May 21 2015, 06:02 AM
I went ahead with the bolt in battery tray idea this week. I drilled and tapped five 6mm holes into the reinforced frame section of the car to mount the lower part of the battery box.
Then I drilled two holes through the top part of the battery tray for 8mm bolts and welded the nuts on the back side of the inner fender well. I added clearance holes in the top of the lower battery tray support to accept five 6mm studs that I had stud welded to the bottom of the battery tray. The test fit looks like everything will fit well once it is painted. Jeff B |
Lo-Fi Version | Time is now: 10th May 2024 - 12:41 AM |
